Thread: New pool need Plumbing recommendations
    Mar 2015
    Port Neches, Texas
    12
    Hey Guys,
    First time pool owner here in Texas seeking advice on plumbing setup. I'm installing a new round 30'x54" Pool Factory 8000 series saltwater pool 20k gallon. My pump and filter will be located 8 ft from the pool on concrete pad. For equipment I have a hayward big mouth skimmer, Pentair 342000 vs pump, Hayward C3030 cartridge filter and a CircuPool Si45 plus SWG. I plan buying a automatic pool cleaner (considering Hayward 5000 Aqua bug) and was wondering if installing a tee with an isolation valve into the suction line from the skimmer to run the vac and skimmer at the same is beneficial.
    Thanks in advanced...
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New pool need Plumbing recommendations
    I am doing it like that, I used a 3 way jandy valve and 1 side will go to the skimmer and the other will be for "the poolcleaner"
