Results 1 to 9 of 9
Thread: Waiting on Test Kit to arrive. Suggestions Please.
    May 2015
    New London, North Carolina
    7
    Good morming. I am a newbie to the site and trying to get started with this season. At the end of last pool season before coving our pool I added a rapid shock and a algaecide and later covered the pool for winter.
    Monday I uncovered our pool to find the water to be very clear. Thinking that I might be off to a good start I filled pool to level started the system and checked for leaks. I had my water checked with the following results:
    FC: 0.7
    TC: 0.7
    CC: 0
    pH: 7.1
    TA: 42
    CH: 130
    CYA: 200
    Sat index: -0.7
    I was told not to add anything to the pool except partial drain and refill to try to bring the CYA down. Is there anything else that I should be doing? The pool water looks crystal clear. I ordered the K-2006 test kit, but it might not be here till next week. Thanks V
    16k gal, 14x34 vinyl in-ground pool, pentair superflow pump 3/4hp, hayward pro series sand filter, pool frog, well water. New London, North Carolina.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Waiting on Test Kit to arrive. Suggestions Please.
    I would recommend adding some bleach as well as partial draining an refilling to reduce CYA. Are these results from the pool store? I am happy to see you ordered a test kit.
    The reason for the bleach recommendation is that your FC is to low and it cannot fight off algae and you could end up not having a clear pool.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    +1 on Bleach suggestion. Where are your test results from?
    Do you have the simple OTO test kit? If so it will get you by until the real kit comes in.
    You can use pool math to get an idea of your total gallons, then dose the pool with bleach accordingly (do this after you do your drain/refill...as you don't want to waste the precious bleach). Hopefully you can get the CYA to a reasonable number before the algae takes over.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Donldson's Avatar
    NW Ohio
    2,880
    First, welcome to TFP!
    If you wouldn't mind, could you update your location to include the state? It helps us greatly knowing what region you live in.
    Assuming your test results are correct (but pool store results rarely are) then you will need to raise your FC considerably to compensate for the very high CYA. You will probably need to replace some water to get that down and keep things managable, but I hate to make recommendations based on pool store testing. CYA is especially their most error prone test.
    I noticed in your signature you have the pool frog. Is that something you intend to continue using? I'm not a fan of it personally, the minerals it adds are silver and copper and the trichlor pacs are very overpriced IMO. Just want to get a feel of how you are planning to care for your pool this season before we start throwing out lots of ideas and suggestions your way.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'm not sure I trust all those test results, especially not the CYA. Are those from a test strip? Or does the pool store use some fancy reader? I doubt they used a drop-type turbidity test (what you'll have in your K-2006) since the scale only goes to 100.
    It's just awful high for a pool that has already had a bunch of fresh water added at the beginning of the season.
    My two cents: split the difference. If CYA really is 200, then minimum FC is 15. If you have no CYA, then shock level is 10ish. 2 jugs of clorox 8.25% will get you to 10. Then add another half a jug every day until the kit arrives. You may need a whole lot of bleach initially, but your pool won't be that voracious all the time. Once it get's balanced, it'll be cheap and easy thereafter.
    When the kit arrives, test FC first. If it's above 10, stop adding bleach and let FC drop, and then you can test everything. Above 10 FC, the pH test reads wrong. Post up your results and we'll be able to advise. In case any of your test results look bizarre, take a gander at Extended Test Kit Directions so you'll see some of the cautions and alternate methods.
    May 2015
    7
    Thanks for all the responses. I have added my location to my profile. Yes the test was done at a local pool store. I was using pool strips. I will try to pick up some sort of kit today if I can locate one. Thanks again. V
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    We recommend the TF 100 or the K2006 for testing. TF is only available through the link in my signature. Not sure if you can buy a k2006 local or not.
    Lisa
    May 2015
    7
    I did order the k2006 kit. Hopefully it will be hear by Monday. V
    May 2015
    7
    Good morning: Still waiting on test kit. After dumping some water and refilling I added some clorox and left running all night. I couldn't find a cheap test kit locally but found strips with cya test. I know the strips are not going to be as reliable but I was curious since the store said my cya was 200. Strip test:
    TH: 100
    FC: between 5 & 10
    PH: 7.2
    TA: 80
    CYA: 100
    Any thoughts? Thanks V
