Thread: Aqualumin 2
    Apr 2012
    151
    Aqualumin 2
    Anyone know of a direct replacement (nicheless) for this light?? I am at a loss. I had one in my pool and removed it. I was that tired of it.
    I now have a customer with 2!! in their pool. Both have had water intrusion behind the lens. Just like every other one I have ever seen.
    At one point there was a chinese company on ebay selling a flat LED light, but I could never tell if it would fit. Did not want to shell out the $150 to be disappointed.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Aqualumin 2
    I have one of those POS lights also. Mine has about an inch of water in it. I have not found a direct replacement. Hayward used to make one that I think was a similar size, but they discontinued it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Apr 2012
    151
    Re: Aqualumin 2
    I think that I could make this work, but I don't want to order 50...
    http://hentech.en.alibaba.com/produc...0_33W_60W.html
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Aqualumin 2
    I wish there was a replacement. My first one had a bulb that couldn't be replaced because of the potting, and the second one is in rough shape.
    This one might be workable but you'd have to use the trim ring from the old light:
    http://www.aliexpress.com/item/led-s...120106828.html
    aliexpress.com has plenty of LED no niche lights, but some only have 2 meter cables.
    This one might work too, but no idea how bright it would really be and I'd have to cut the cord of my existing light just to try it. http://www.ebay.com/itm/PC-Resin-fil...57455570&rt=nc
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Aqualumin 2
    What do they expect you to do with a 6.5ft cable? Stretch it?
