Thread: Clogged Skimmer Line
    I was vacuuming and clogged my skimmer line. I tried putting a hose wrapped with a towel in the pump end and built up pressure but it didn't work. I've heard some people use a drain king but I dont think I can get that into the line. Any other ideas?
    PVC lines
    Gunite. 14,869 Gallons. Hayward cartridge filter. Hayward Super Pump 1HP. Chlorine.
    Baltimore, MD
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Clogged Skimmer Line
    Quote Originally Posted by RSAnative View Post
    PVC lines
    Blowing it backwards is the best thing, but if you can't get in there, then try a plumber's snake from the skimmer end. OR, if you have a wet-n-dry shop vacuum and can get a good seal between the end of the vacuum hose and the skimmer hole, try sucking backwards.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Often building pressure and then running the pump over and over will eventually work it loose. Do you know what the clog is?
    Not sure what it is. Possible twigs? I've heard plumber's snake can damage the line? I will give the wet-dry vac a try.
    Baltimore, MD
