Thread: Autopilot Shutting it off
    Aug 2014
    East Northport, NY
    155
    Hi.
    The unit (DIG-220) is currently NOT tied into the pump but will be in the future. In the interim, what is the best way to shut it? The pump runs on a separate times so when that goes off is it ok to leave the unit plugged in and it will cease producing or do I have to manually unplug it each time before the pump shuts? If the latter, will it lose the programming I have (30K gallons, etc).
    Couldn't decipher this from the manual.
    Thanks!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Autopilot Shutting it off
    I don't have any idea Amanda, but I am sure someone will
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Most swg's have memory to save any settings because they are usually cycled on and off with the pump. The low flow switch is also not supposed to be used as the primary means of shutting the unit off because if the switch fails, the cell will fill the line with chlorine and hydrogen. I would unplug it when the pump is not running, and get it hooked up to the pump timer asap.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    East Northport, NY
    155
    Much appreciated- will manually do for the time being
    TF-100 Test Kit
    Aquabot Bravo
    JoshU's Avatar
    New Orleans, LA
    542
    Yes the Pool Pilot DIG-220 (or any other AutoPilot Pool Pilot controller) does hold memory when the power is turned off to the unit.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
