Thread: Sun Damage to the liner
    I haven't seen much on the topic of sun damage, so hopefully some good ideas or suggestions will come from this. I live in California where the summers are long and HOT. My pool sits in direct sunlight the entire day and therefore takes quite a beating. Back a few years ago when I had the quick-set pools with the inflatable ring, the sun would destroy it by the second season. I used to think the ring was defective because it would always lose air, I would spend hours like a cuckoo bird searching for the hole. Then by season two the ring would disintegrate just looking at it.
    It was exciting to have a new and improved bigger pool that does not have the inflatable ring. The outside of the liner is a light gray so I was hoping this would help combat sun damage. But by the end of the summer last year the tops of the liner suspended on the frame had already discolored. My mind went into preventative mode.
    I tried to modify a pool noodle to wrap around with no such luck. I looked into foam pole wraps but they were ridiculously expensive. Thought about cutting up and old raft and using to wrap but thought it might actually compound the problem due to the heat. I ended up going to Lowes and buying a shower pan liner which looks more like a rubber mat. It was sold by the foot and was already premarked in 12" wide columns. I think I bought about 6 feet and had a ton leftover. I cut each piece 6x30 and used a hole punch to put two holes on each end. I draped the rubber barrier over the liner and fed a 14" cable tie around the frame and through the holes to secure. I made sure the cable tie connection was under the frame to prevent snags. I snipped off the extra for ascetics! Since the liner material is gray it blends pretty well and doesn't look too ghetto. So far it doesn't seem to get any hotter than the frame.
    Has anyone else had this problem and what was your solution?
    20x45 in-ground 42k pool and spa built in 1989. Just moved into this home and am still in the learning phase of understanding equipment
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Sun Damage to the liner
    I a have a smaller Intex and have to experienced this yet. This is the pools 2nd season in the AZ sun. We left it up all winter.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Quote Originally Posted by Azgirl71 View Post
    You've been lucky! I'm just doing preventative maintenance to increase the longevity of the liner.
