Results 1 to 13 of 13
Thread: I want to deep clean my sand filter...
    May 2015
    Russellville, AR
    4
    I am positive my sand filter has never been cleaned, let alone deep clean. Already started the pool for the season, can I still do a deep clean? If so , do I disconnect all the plumbing from the sand filter? or is there an easier way? Thanks for all your help!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: I want to deep clean my sand filter...
    You need to be able to remove the top of the filter to get to the sand. If you have a multiport on the side then just remove the top. If the multiport is on top then you may need to cut the pipes if you do not have unions. If you do not have unions this would be a good time to add them to your set up. Post a picture of your filter and plumbing and we can tell you if there is any alternative.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Nope, no easier way. You gotta be able to get the multiport off. Did mine last year and re-plumbed one more union into the mix so it's a no brainer next time. I suggest you reach in and scoop all the gunk out off the top with your hands as possible before floating all the rest out with a hose jabbing it gently into the sand bed. You ain't gonna believe how much will be caked up around the top edge of the sand bed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Here is a dandy instructional article on how to deep clean a sand filter.
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Jun 2015
    Cedar Park, TX
    12
    Is the deep clean more effective if you first drain the water out of the filter? Wondering if exposing the top layer of sand makes it easier to remove debris.
    15,000 IG Plaster
    Pentair TR-100 Sand
    Pentair IC40 SWG
    Pentair EasyTouch with ScreenLogic2
    38,361
    I doubt it. Because when you put the hose in to start washing out the debris you're going to have to fill the filter back up.
    Oct 2015
    Lynchburg, VA
    23
    I also want to clean my sand filter, but when I tried to disassemble the lid of the sand filter I also noticed the plumbing. Tried to use a pipe wrench on the one connection on the right side, but it would not budge, it only made impressions in the plastic. Here's a picture of the lines hooked up on the left side. Any advice on disconnecting these? There will be no way to remove the lid unless I disconnect the three hookups.
    IG 26k gal, vinyl liner, Hayward S220T sand filter, Hayward SP2607X10 pump with Century UST1102 motor (single speed)
    Goldline AquaRite swg with Tcell-9
    TF-100 test kit
    located in Central Virginia
    38,361
    You will need to cut the pipes and add unions that allow you to twist and remove the top of the filter.
    Oct 2015
    Lynchburg, VA
    23
    Thanks, Jason. I'm not a plumber, so what do you think: would it be worth it to hire someone to do this, just so I can get the sand filter open for cleaning? Or will frequent backwashing do the job?
    TF-100 test kit
    38,361
    A few YouTube videos and I have no doubt you could cut and add unions.
    Oct 2015
    Lynchburg, VA
    23
    OK cool, thanks. I guess it's not rocket surgery, then...
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by cbosterhus View Post
    Buy yourself some fittings, some primer, and some glue. Take a hacksaw to the pipes. Don't forget to slip the outer ring on before you glue things together.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I learned the hard way, the unions at Home Depot are not very good. The Hayward or Spears are better.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
