Thread: My new Fas-Dpd testing kit
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Hello,
    I just receive my new test kit and i have some questions
    1- when i use 25 ml, i add 5 drops to found cc, but when i use 10ml sample, shoul i also add 5 drops?
    2- some one use 5 ml sample (each drops is 1ppm)?
    3- there is an example (10 ml sample):
    0 drop - pink
    1 drop - pink
    2 drops - pink
    3 drops - pink
    4 drops - light pink
    5 drops - clear
    What is my ppm level?
    Thanks !!
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: My new Fas-Dpd testing kit
    Congrats on your test! 5 drop clear multiplied by .5 = 2.5FC
    That was to answer 3 for you. I don't know the answer to 1 or 2. I always use 10ml
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    With a 10ML sample you add drops until its CLEAR then take that number and multiply it by .5 so with 5 drops turning it clear your FC level is 2.5!
    Now all you need to do is add bleach to get that level up!
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    The only people who use a 5 ml sample are generally those involved in clearing a swamp who are running short of reagent.
    And yes, still 5 drops of the second reagent to test CC.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Quote Originally Posted by Z7What View Post
    My FC is ok, i just skip some line in my exemple
    Thanks for the answer, thats was the idea and also reagent are expensive here in Canada!
    38,284
    1) Yes add 5 drops for the CC test whether you use 10ml or 25ml water sample.
    I think the others were covered.
