Results 1 to 13 of 13
Thread: Re using valves
    Southern Indiana
    229
    Re using valves
    Hi folks, I want to replace my suction side. I added two jandy never lube valves in the spring to try to stop what may be a suction side leak, it didn't help. Now I want to pull it all out and try again. I saw on YouTube where they were cutting the pvc close to the fitting (valve in my case) then using a torch to heat the pvc then use a screw driver to pry the pvc out so they could get players in and they twisted the pvc till it pealed out... Do you think that works? I want to put my backup pump in with a new suction side... I would like to keep the valves since they are only s few months old.
    Thoughts?
    Example:
    http://youtu.be/CfezjNDNxNo
    https://m.youtube.com/watch?v=1DGRKMfUbwQ
    30,419
    Re: Re using valves
    I have never tried that. It sorta' makes sense but obviously you have to be careful with that torch. I would be afraid to make my first attempt on a valve. Maybe just glue up a scrap PVC joint and practice.
    Southern Indiana
    229
    Re: Re using valves
    Good idea to practice before trying on the valve... Going to look for some pvc to try that tomorrow.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Re: Re using valves
    I know your pain. I saw a video and want to try it. I have some 2" ball valves from when I re-did my plumbing. I saved them to maybe try it down the road. let us know if you try it out and what your experiences are.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Re using valves
    I would be afraid that the heat would damage the valve seats. You can recover those valves by using a "socket saver".
    Example:
    http://www.amazon.com/Jones-Stephens.../dp/B000HE9YS8
    Local plumbing supply stores should carry them too.
    I own the 1 1/4" size and have used the 1 1/2" size. They both work very well.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Re: Re using valves
    The valves have two sizes. For a 1.5" x 2" valve, the valve takes 1.5" pvc pipe into the hole or a 2" coupling on the outside. For a 2" x 2.5" valve, the valve takes 2" pvc pipe into the hole or a 2.5" coupling on the outside.
    If you cut the pipe flush, you can use the other size not yet used.
    Another option is to use a pipe extender. A pipe extender glues inside of schedule 40 pvc pipe and leaves about 1.5" of new pipe. I don't like using them on 1.5" pipe as it reduces the diameter too much. A 2" pipe extender is less of a concern as far as diameter is concerned.
    Support the site
    38,284
    Re: Re using valves
    I think I would try a ram bit before torching it. At least we have had a few members post success with a ram bit.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: Re using valves
    I have used the torch method with great success. What really helps is that the valves are constructed of CPVC which withstands some heat much better than PVC. Use a heat gun if you are not comfortable with a torch and make sure the valve body is positioned on the opposite side of the valve so it doesn't deform from the heat.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Re: Re using valves
    I have seen something similar to these being used on "This Old House".
    Quote Originally Posted by Propbndr View Post
    Example:
    but these would save $$ and they seem to work as well.
    AG 24' round 15k gal
    cartridge filter 125sf
    Southern Indiana
    229
    Re: Re using valves
    Thanks guys!!! Some good ideas I didn't even know about. T plan on cutting it out this weekend... I will follow up and let you know.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Re using valves
    If you have a plumber friend, perhaps they have a set of these and would hook you up for a beer or 2.
    Steve
    Southern Indiana
    229
    Re: Re using valves
    James W you have a point... I forgot the valves were both inner and outer installs.. I may do as you stated, and use 2" - 1.5 inch unions to get them back in. I also glued up some scrap to see how the torch method works... and I may order one of those socket savers or one of those ram bits... more to follow... Might be worth trying the ram bit on the valve, if I don't like the end result, I still have the outer diameter to use...
    Pool 16 x 33.5 Foxx Pool with rounded corners 3.5 at each end and 5+ in the middle (16000 GAL)
    Equipment - 300 LB Hayward filter with a Pentair SuperFlo pump (3/4 HP). Also Hayward H series Heater and a dedicated jet for a Polaris 280 with a booster pump (3/4HP). Hayward Chlorinator CL200.
    Pool has Main Drain, 2 return Jets with 1 inch eyeballs, a skimmer with floating weir, and the dedicated Polaris jet. Also has a valve for the Waterslide.
    Southern Indiana
    229
    Re: Re using valves
    Guys, I wanted to get back to you on this... I tested the burn and re-use method... and it did work... but I would need to practice a few more times to even feel comfortable enough to try... I am going to reuse the valves, but I am just going to use the over method (2 inch outer) then adapt to 1.5... I am afraid I will damage the valve... but I do believe with practice and hard work it will turn out fine... I will post my lame video in a few... I am playing it safe on this one...
