Results 1 to 9 of 9
Thread: Solar Covers
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Solar Covers
    I was just reading a post about what solar cover to buy. The general census was that the Blue is better with protecting the FC levels but doesn't do much warming, the clear does much better with warming but doesn't protect the FC levels.
    I live right outside of New Orleans so its get pretty freaking hot doing the summer. My pool is actually 80* right now. The wife thinks that its to cold still and I find it hard for me to get her to come swimming if its too cold. Doing the summer the pool gets HOT, cant remember exactly how high but its hot.
    With that being said does the blue warm the pool any? I think what I would want is some thing that would heat it a little but do more for protecting the FC.
    Or is there any other style cover that would be better for my goals?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Solar Covers
    with those temp's I would go for an 8 mil blue like this.. http://www.amazon.com/Blue-Wave-24-F.../dp/B003B15B22
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Solar Covers
    You have to keep in mind your water will heat better on a nice hot sunny day with little wind with the cover off. The covers work best at retaining the heat at night that you would lose to evaporation. So when your done swimming for the night put the blanket on your water till your ready to swim again.
    Jeff
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Re: Solar Covers
    I also read that people cut theres in to sections, why is that? Wouldn't they move around?
    Wayne
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Solar Covers
    Quote Originally Posted by Z7What View Post
    Wayne
    It makes them more manageable. I cut mine in half for this reason. Mine doesn't move around even with the pump running on low speed. On high speed it will start to spin.
    Jeff
    Casey's Avatar
    SW PA
    10,446
    Re: Solar Covers
    I have mine cut in 4 pieces, right down the seams so I roll it on and off in 4 pieces.
    The best time to use the blanket is at night. I can warm my pool fastest by shutting my pump off and letting the Sun blast my water for hours on end and then cover the pool around 7-8pm.
    Mar 2014
    south central PA
    112
    Re: Solar Covers
    Casey, do you have any pics of your cut solar cover? Or can you give a description of how you did, and then how you go about putting the cover on and off again? I was thinking of doing something like this to make a solar cover more manageable.
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Jun 2014
    Rogers, AR
    424
    Re: Solar Covers
    Quote Originally Posted by Casey View Post
    Should I be turning the pump off during the day when the cover is off?
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Solar Covers
    I would run it with cover off.
    Dolphin E10 Cleaning Robot.
