Thread: DIY Section
    May 2015
    keller
    129
    DIY Section
    Perhaps you have thought about this before and there is good reason for it, but I thought it would be great if there was a DIY pool build section.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: DIY Section
    One thing we try to do is keep the Forums on TFP to a bare minimum. These builds are featured in the "Under Construction" forum at this time and we hope to continue to see more.
    Welcome to TFP! We hope you enjoy your time here.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: DIY Section
    This also causes confusion, do you put a heat pump somone installed themselves with the other heaters, or do you put it with DIY...
