Thread: First numbers in. When to add CYA?
    May 2015
    Bel Air/Maryland
    4
    First full set of numbers are in.
    FC - 5.5
    Salt - 2730
    CC - 0
    CH - 75
    TA - 60
    CYA - 25
    pH - 7.2
    I added 30lb of salt but I'm not sure whether to adjust the pH first or add some CYA. I'm not sure what interacts with what.
    13000Gal / AG / Saltwater / Cartridge / Hayward Power-Flo LX Pump / Pool Age 5yr / TF-100 kit / Hayward Goldline Aquatrol SWG / Hayward Goldline Turbo T-Cell-5
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: First numbers in. When to add CYA?
    You can do pH & CYA at the same time, but I wouldn't bother with the pH. As soon as you turn the SWG on the pH is going to begin to rise..
    Measure the amount of CYA Pool Math says you need and put it in an old sock. Either put this sock in the skimmer or hang it in front of a return. When raising CYA do it in two or three additions, testing between each. Remember, it can take up to a week for CYA to register on the test, so don't get frustrated in a few days and put more in.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Here are some intro Pool School articles to read.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for your SWCG pool.
    Use PoolMath to figure out how much to add.
    May 2015
    Bel Air/Maryland
    4
    Should i keep the pump running 24/7 with the cya in front of a return or let the pump switch off at night?
    May 2014
    Franklin, NC
    9,184
    No need for 24/7.
    Support the site
