Thread: Adding CYA, all at once or in 2 steps?
    Jan 2015
    Palm Springs, CA
    29
    I just drained and refilled my pool to fix high CH problem. When I refilled the pool I checked water meter at start and finish, so know the volume.
    According to PoolMath, to get CYA to 70 for my SWG pool I should add 3 lbs, 14 oz.
    I added the first 3 lbs via sock in front of return method yesterday, which should take it to 54.
    My question is, do I need to wait a week, test the results, and then add the remaining CYA?
    Or can I just add the remaining 14 oz today (while monitoring pH) and trust PoolMath that it will go to the right amount?
    Don't want to get my CYA too high, but I trust my ability to weigh the CYA more than my eyes to read the results of the test.
    6640 gallon outdoor in-ground 8x26 pebble pool, 3'-5' deep, Pentair IntelliFlo Variable Speed pump, Jandy CL580 Cartridge Filter, Jandy AquaPure 1400 SWCG
    38,290
    Re: Adding CYA, all at once or in 2 steps?
    How much water did you replace? How sure are you of the volume of the pool?
    I think I would wait a week, retest and then add more.
    Jan 2015
    Palm Springs, CA
    29
    I drained it completely so I replaced all of the water.
    I am pretty sure of the volume since I used the water meter at the street at start and finish of refill.
    38,290
    Well, then PoolMath should give you the right amount to add ... it is not like going a little over 70ppm is a big deal anyway.
    Jan 2015
    Palm Springs, CA
    29
    The other thing, is according to this post:
    http://www.troublefreepool.com/threa...l=1#post203524
    The accuracy of the test, is plus or minus 15. So if my first addition takes me to 55, the test results could give me 40 to 70.
    So I figured it would be more accurate knowing the volume, to just trust PoolMath.
