Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Not sure where to start...HELP!
    May 2015
    Spanish Fort, Al
    18
    Been relying on the pool store pretty much but hot my Taylor k 2006 test kit today. Water is blue now but started as a nasty dark gross green. It is extremely cloudy. I can maybe see 5 inches of the wall. Scooped out all the leaves we could. Haven't been able to scoop anything else so hopefully we got out everything.
    I have read so much, my head feels too full(if that makes sense).With the below numbers, where do I start first? I was hoping that some of the numbers would be on spot but apparently not. Also, with the CYA, the black didn't disappear even after filled to the top. I know the pool store test can be off but last week they said CYA was only 4(pretty much non-existent).
    FC .5
    CC 2
    PH 7.0
    TA. 50
    CH 210
    CYA black don't didn't disappear
    18x36 Vinyl inground pool
    26,700 Gallons
    Hayward 1hp sand filter
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Not sure where to start...HELP!
    Welcome. You will need to get add Stablizer in a sock and set it in your skimmer to dissolve. Target a 30 CYA using pool math. Also you need to at least add enough bleach to target 2 for now until some CYA is in there.
    You also need to bring your TA and PH up a little but I will let someone else address that. I know you will need to SLAM based on your CC and how you describe your pool. PH will need to be 7.2.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,305
    Welcome to TFP!!!
    Did you add any CYA? If not then it would still be near zero. Target about 30ppm as Lisa said.
    After getting the CYA dissolving in a sock in the skimmer, then start following the ShockLevelAndMAINTAIN Process.
    May 2015
    Spanish Fort, Al
    18
    I forgot to mention, I did have a pound of CYA in a sock in the skimmer. Not sure how much that will raise it, but it was all dissolved Sunday night. So do I factor in that pound in pool math?
    26,700 Gallons
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes, once you figure out your gallons factor in the lb you already added.
    Lisa
    38,305
    Yeah, you need to come up with a volume estimate to know where your CYA might be.
    May 2015
    Spanish Fort, Al
    18
    Figured pool to be 26,700 gallons. How do I know how much a pound of stabilzer adds? In pool math can I just put in 0 for now and target of 30 and then take away a pound to know how much I need now? Not trying to get ahead of myself but would I start the SLAM process today or no? Lisa said keep it at 2 for now until there is more CYA(of course I forgot to mention the pound added before she commented), Jason said SLAM after putting in sock with stabilizer. Probably confusing myself. Not sure on my shock level either with CYA being under 20.
    26,700 Gallons
    38,305
    At the bottom in the Effects of Adding Chemicals section you can see what 1 pound would have added.
    Or do as you suggested and just add 1 pound less than the recommendation to get the 30ppm.
    You can start the SLAM right away. Just get the CYA dissolving and target a FC of 10ppm. Once the CYA is dissolved, raise your target FC shock level to that in the FC/CYA Chart. After a week, verify your CYA level.
    May 2015
    Spanish Fort, Al
    18
    Thank you!
    26,700 Gallons
    May 2015
    Spanish Fort, Al
    18
    I have another question. I have to go out of town for the weekend. Started the SLAM process today. My husband may stay here or may go. If he stays, he will be gone all day and won't be home until between 8:30pm-10pm. How much chlorine should he add in the morning before going to work since it won't be tested during the day to keep fc at 10? Also, if he ends up going with me, should I add loads of chlorine before leaving and hope it holds until Sunday evening?
    26,700 Gallons
    38,305
    You should not raise the FC level much above shock level. Just do the best you can.
    May 2015
    Spanish Fort, Al
    18
    Ok. Thanks. He isn't going so I'll do my best to make sure he knows what to do.
    26,700 Gallons
    May 2015
    Spanish Fort, Al
    18
    Yesterday when I got back in town, I tested the water and FC was a 5. Well, my husband has been using cal hypo because he didn't want to buy bleach over the weekend. I decided to just use up the rest. Added the recommended amount last night. Before I went to bed, FC was 10.5. Well, this morning it was a 6. Added the recommended amount and checked it 2 hours later and it's a 5! Not sure why it was only 5, two hours after adding the cal hypo. CC is .5 when I checked this morning. CYA is still not registering. Trying to wait until Thursday to see if it will register. Then and I'll go from there with the CYA.
    26,700 Gallons
    38,305
    During the sun light, the FC will drop rapidly if your CYA is very low.
    So how much stabilizer have you added? You mentioned 1 pound was added and then we discussed calculating to add more to reach 30ppm, but you did not report back about that.
    May 2015
    Spanish Fort, Al
    18
    I added another 3 pounds. I guess I was shocked at the rapid decrease because it hadn't dropped that much in an hour with it being sunny over the weekend. It got down to 5 Saturday evening but that was a whole day's worth of sun. Now it's at 2, few hours after I added more to bring it to 10. I think it's the cal hypo maybe. Wondering if my husband left it outside. I can't get any bleach until after 6, unfortunately. I will get some more stabilizer too.
    26,700 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    It is very important to keep your chlorine level above the minimum for your CYA level at all times. Every time your chlorine level drops below the minimum algae starts growing again. Chlorine CYA Chart.
    Be careful on adding more CYA/stabilizer. You definitely do not want to add too much. Total up how much you have added and verify the level in Poolmath. The only way to lower CYA is to partially drain your pool water.
    May 2015
    Spanish Fort, Al
    18
    Yes, I know it needs to stay above and right now shock level should still be at 10 according to the chart. I'm waiting until the CYA will register before I add more stabilizer. I couldn't make it to the store this evening for more bleach due to a very sick child. I'm sure FC has been a 0 not too long after my last post.
    26,700 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You don't have to wait if you are confident about your volume and careful with the dose. Once it's in, just plan on that as your Cya level.
    Essential Links:
    May 2015
    Spanish Fort, Al
    18
    Ok, so my husband got impatient with this process. After I told him, it just takes time and we have to be patient. He flocked twice. Yes it did work but made more work for me. Anyway, the pool has been sitting without being turned on for awhile, because I had to wait for him to fix the oring on the filter so I could vacuum. Well I vacuumed today. Went and bought some great value bleach. Poured it in and now my water is green. Before I put it in, it looked clear and looked blue in the shallow end. The deep end was blue green and cloudy but I could make out the bottom. Now it's just green! Scared I picked up the wrong stuff.
    ETA: It's says on the jug Great Value Bleach with a small 1 at the end of bleach. Is it the wrong stuff?
    26,700 Gallons
  20. Back To Top    #20
    38,305
    Sounds like you have metals in the water that reacted to the bleach to turn the water yellow.
    You would need to start using a sequestrant. See: Pool School - Metals in the Water and Metal Stains
