Thread: Starting up Brand New IG Pool
    Mar 2015
    Las Vegas NV
    460
    I've searched high and low and cannot find a post on this, maybe my search-fu is weak today.
    I'm planning on using the TFPC method for my pool, however, most of the start-up posts seem to be geared towards existing pools opening-up at the beginning of the season. Is there a post that details starting-up a brand new pool? I suppose it's the same, however, my plaster guy just told me to remember not to add salt to my pool for 30 days. I asked him about bleach and he said to be careful how I pour it in because he wouldn't want it sitting on the plaster because it could discolor it. So I'm thinking I'll use trichlor tabs in a floater to bring my chlorine-up and I believe an added benefit is they also build-up CYA.
    Can anyone direct me to a post on new IG start-up directions. Thanks in advance!
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Starting up Brand New IG Pool
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2015
    Las Vegas NV
    460
    THANK YOU! I knew it had to be here somewhere, like I said, my search-fu was weak today. Thanks again!
    38,370
    Waiting on the salt is a good idea. Using bleach is fine, however, assuming you add it in the manner we recommend ... and running a brush can help ensure it is mixed.
