Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: Can this work with my Pool?
    May 2015
    canada, montreal
    28
    can my pump work if i want to add on my shelter (8 foot high) 100ft pvc tubbing?
    thank you
    18 X 52 intex ultra frame pool, intex sand filter 1600 gph
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Can this work with my Pool?
    Welcome syko,
    Can you give us more information please?
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Are you trying to build a solar heater?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    canada, montreal
    28
    Yes i want to build a solars heater system for my pool and i want to install the tubing on the roof
    Thanks
    38,251
    It is much cheaper and more efficient to buy the commercial solar heating mats. Solar heating is about exposure to the sun and high flow rates and that is best done with a mat.
    Trying to force the water through a long small tube is going result in a lot of head loss and very little heat gain.
    May 2015
    canada, montreal
    28
    Here is my setup
    Thank you
    May 2015
    canada, montreal
    28
    But i want to spend max 100$ and does my pump can push the water to the top of my shelter and sfter in the heating mat?
    Thanks
    Do you hva some model to refer me please?
    38,251
    There are inexpensive mats all over Ebay. Would you rather spend $100 and the effort to put some tubes up and have it not really make a difference?
    Honestly the Intex pumps are pretty weak, so I am not sure if it could support a solar system on the shed. It probably could if you left the mats on the ground.
    May 2015
    canada, montreal
    28
    Oooo ok and if i leave it on the ground can it heat the pool the same as if it was on a roof?
    38,251
    Sure as long as the sun is shining on them, you may get a little less heating just because the ground / grass is cooler than the shingles.
    May 2015
    canada, montreal
    28
    Is it only the sun who heat the water can i pass my pvc pipe in my shelter if in the summer its getting very hot?
    Or its like doing nothing?
    Thanks
    May 2014
    Lake Forest, IL
    53
    How much of a temperature increase are you expecting to get? I dont think these panels are going to make that much of a difference. I am sure your nights get pretty cold similar or moreso then chicago even where I am.
    Intex Ultra Frame 16' by 48" deep - Pentair Superflo 1.5 HP pump with sand filter, Hayward H150 Heater, Hayward Skimmer and 2nd return
    May 2015
    canada, montreal
    28
    Yes its look like chicago but i just want to have more than 64f lol i want like 78 -80f
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    For the money, a solar cover would be a better investment imho.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Orlando, FL
    690
    Are you using a solar cover? The best thing you can do while trying to decide on solar panels is to get a solar cover to help reduce the nighttime heat loss.
    Jeffchap, we were typing at the same time. I just had to split my attention with the kids in the pool. Lol
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2015
    canada, montreal
    28
    Yes i do use solar cover
    Orlando, FL
    690
    Quote Originally Posted by syko128 View Post
    Good to hear. That should help a lot. Beyond that, I would suggest you buy panels. Search around, you can find them relatively inexpensive and they also show up on Craigslist.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    at 18 foot your surface area is 324 sq feet, to raise your temp with solar panels you would need 75 to 100% surface area of your pool. You would have to buy 4 to 8, 2x20 foot solar panels to reach 50 to 100% of your surface area.. your talking 900 for half the surface area of your pool just for panels, and those are the cheap ones that you will have to replace within 5 years.... the nice ones that will last will cost 3000 to 6000 dollars.. if that's not enough you will probably need a new pump setup to make solar panels work unless you place them on the ground.. if you really want or need them get some good ones.. I did a lot of research and decided to go with a 16 mil clear solar cover with reel..
    May 2015
    canada, montreal
    28
    What is a 16 mil clear solar cover?
  20. Back To Top    #20
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It's a thicker, clear bubble solar cover.
