Results 1 to 11 of 11
Thread: Hello:
    May 2015
    New London, North Carolina
    7
    Hello:
    I'm new to TFP. We are in the 4th season with our pool and looking for more cost effective means to take care of our pool. Looks like a great site. V
    16k gal, 14x34 vinyl in-ground pool, pentair superflow pump 3/4hp, hayward pro series sand filter, pool frog, well water. New London, North Carolina.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello:
    Welcome the the forum!
    You'll be hard pressed to find a better cost option than TFPC. If you do, let us know, we would be interested in that.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Hello:
    Welcome to TFP!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,290
    Re: Hello:
    Welcome to TFP!!!
    A really easy way to save money right off the bat is to stop putting the mineral packs in the Frog. They only lead to bad things like green hair and stained pools.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Hello:
    And mineral frog packs are expensive
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    7
    Re: Hello:
    Thanks. Funny you mention the mineral pack, It was suggest by my pool folks that I keep it this morning when I had them test my water. I chose not to get it. Had them test water this morning really high cya, been draining and refilling today. I have been doing a lot of reading today. Will order Me a good test kit today or tomorrow.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello:
    Good for you. A good kit is essential.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Hello:
    Quote Originally Posted by vwhit View Post
    If it's already there, I wouldn't remove it. It is an easy to use chlorinator when you go out of town. Save the empty mineral pack to hold the chlorine pack in place should you need it.
    Casey's Avatar
    SW PA
    10,444
    Re: Hello:
    Welcome! You've come to the right place!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Hello:
    WOW! You already plan to get a good test kit? That is awesome to hear! You are going to LOVE taking care of your pool now and will not believe how easy and cheap it will be with the test kit!
    Let us know when it gets in and we can help you out with the testing.
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hello:
    Welcome to the forum!
