Results 1 to 13 of 13
Thread: BORJIS: Bio-Active cya reducer trial
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    All chemistry within TFP recommended specs except cya which is 100
    on a 1:1 dillution test done last saturday.
    Water Temp: 66 degrees
    Free Chorine: 3 ppm
    Here we go!
    No sunny weather forecasted until saturday or sunday so I'll post
    cya tests when I can.
    Dolphin E10 Cleaning Robot.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: BORJIS: Bio-Active cya reducer trial
    Awesome, let's see what this one does.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    We've just been talking in another forum that it would be interesting to see one of these done with Zero FC.
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    That would be interesting.
    I might have volunteered for that during the late part of this season, but I'm putting my
    house on the market next month and couldn't risk an algae bloom.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Quote Originally Posted by borjis View Post
    When it sells, leave this on the counter for the new owners: http://www.troublefreepool.com/threa...Business-Cards
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Haha! Richard! YOU KNOW IT!
    I'm leaving the TF-100 kit on the kitchen counter along with testing notes and to join this forum.
    Hoping my next house has a pool but if not I'll be looking for something with room in the backyard
    for a vinyl in ground or fiberglass.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Pool temp: 68 degrees
    FC: 2
    as of yesterday.
    will do a cya test sunday (5th day of bio-active working) when the sun comes out.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good deal, we'll look forward to you numbers.
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Day 6 of Bio Active reducer test results.
    (No dillution)
    fc: 2
    Water temp: 62 (just turned solar on)
    Drum roll.......
    Cya: 80 ppm
    So a 20ppm reduction in 6 days.
    Lets see how much further it goes.final test next Saturday.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I tested FC monday and it was unexpectedly at .5, so I added a 1/2 gal of generic Winco 8.25 % bleach
    and ran the pump for 2 hours. The instructions do say to maintain minimal sanitizer.
    This morning the FC level was 4.5 (still under 5) a little higher than I thought it would end up (thought it would be 2.5)
    water temp is 70 degrees.
    I wish now I would have added 1/4 instead of 1/2 gal, but my house is going on the market in 2 weeks and from
    the two folks who had green water or algae growth when doing the bio-active, I just couldn't risk it. Gotta have sparkling clear water for the showings to buyers.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    ok my run with the Bio-Active is complete.
    Just did a CYA test....no change from mid way through.
    Average water temp during run: 68 degrees
    Final Result 80.
    So it reduced it 20ppm.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not good when you consider margin of test error can be as much as 15 PPM. Nothing yet.
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Thought I should update this thread that around the end of the trial, I noticed some yellow ish color by my steps.
    I thought it was metal staining but when I scrubbed it with a brush a massive white cloud came out....Mustard Algae.
    wonderful.
