Results 1 to 7 of 7
Thread: New to TFP and new pool owner!
    May 2015
    Victoria MN
    2
    Hi everyone! I hear great things about this forum so I am excited to get started. I tried to fill out my signature with some info but couldn't find much about the 16 ft Intex pool I bought. I'm hoping someone can recommend:
    -best testing kit to use (Taylor?)
    -best starter kit for chemicals, or
    -what chemicals to buy
    -any other recommendations off the top
    Thanks!
    First time pool owner, Setting up for the first time May, 2015.
    16 ft x 48 in Intex steel frame above ground pool from Target
    1500 gal/hr pump with standard filter
    Still learning other details
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New to TFP and new pool owner!
    Welcome to to TFP!!
    You will need to pick up one of the recommended test kits. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All the kits on the list contain that test while very few other kits do. The kits sold at the pool store generally won't won't cut it, but be careful pool store employees are known to say “it's the same thing”. Generally it's not! The best for most pool owners is the TF-100 because it has been set up to provide more of the reagents a residential pool owner will use, rather than a commercial pool. It is based on Taylor chemicals.
    Skip the started kits as they always include a bunch of stuff you don't need and we don't recommend. Stop by WalMart and pick up a container of CYA/Conditioner and a few bottles of 8.25% bleach. Other then that lets test the water before you "stock up"
    Support the site
    Apr 2015
    Macedonia, OH
    86
    The two main kit recommendations are the Taylor- K-2006 and the TF-100 (only at TFTestKits.net)
    I bought the Taylor, but realized shortly after that you get more with the TF-100, and replacement chemicals (which you should replace yearly) are cheaper than the Taylor replacements.
    If you plan on following the TFP methods, there is no "starter kit" of chemicals.
    I will let more knowledgeable people comment on chemicals to buy, but generally you shouldn't add anything until you can get a good idea of your current levels with a reliable kit.
    Other than that, read everything in pool school (link above) then read it again. You will be more knowledgeable than any pool store "professional" at that point.
    25k Gal, IG Vinyl, 26" Sand Filter, Hayward 1HP (SP-2607x10), Installed late 90s? (bought house in 2015), K-2006 Test Kit w/ SpeedStir & extra reagents from TFTestKits.com (Buying TF-100 next year instead of Taylor refills!)
    Helpful Links - Pool School - Read Everything Twice! : SLAM Procedure to clean up a green monster : CYA-FC Relation Chart : Pool Math Calculator : My First Pool Opening
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I just wanted to say welcome to TFP! Good for you on wanting to take over your pool. I love my TF 100!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Victoria MN
    2
    Awesome. Thanks for the quick replies everyone. Pretty excited there is so much support. I'll grab the above listed items, re-read pool school, get the thing set up in a few days and do some testing. I will be back with more questions for sure
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Welcome!
    Besides the test kit, the CYA, and some bleach, you'll also need a few tools.
    A thermometer, a pole, a brush head (nylon, not stainless steel) a leaf skimmer, and probably some kind of vacuum. The good news is, everything there but the brush head will probably outlast the pool, so it's just a one-time expense.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Welcome! I'll throw in another recommendation for the tf-100. I have the same pool only 2 feet bigger. TFP is a great place to learn and get tons of help for taking care of your pool.
    If this is your first time setting up pool in your yard remember the most important thing is to make sure it's level! It's usually the most annoying part of setup but it's necessary.
    Have fun with your reading and if you come across something you don't understand, ask away!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
