Thread: Spa Startup
    Jun 2014
    Thompson, ND
    33
    Spa Startup
    What is the proper order to balance water when opening a hot tub for the first time? Do you do TA then PH then sanitizer? Or is it in a different order to get them all balanced.
    21,000 gal AG 30 foot round pool. Sand Filter. 1.5 hp pump.
    360 gallon 2015 relay hot springs hot tub
    North Dakota
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Spa Startup
    Here is an excellent write up on caring for water in your hot tub. I use it in mine and my water is great. Be sure to add the borates, it adds a lot!
    http://www.troublefreepool.com/threa...-Spa-(or-pool)
