Thread: Wemo for pool light?
    Jun 2014
    Wading River, NY
    15
    I've found a few old threads about using timer switches for pool lights, but I'd like to take it a step further and replace my existing switch with a WeMo switch. My filter (and the pool light switch) are in a dark corner of the yard that no one but me likes to walk over to at night, so I'm trying to make it easy to automate the light and turn it on without walking across the yard.
    I already have another WeMo switch controlling the lights for my pool bar, which is about the same distance from the house, and it works flawlessly. My question is if anyone has already tried this. I'm thinking the metal housing for the pool light switch may interfere with the wifi signal. I have already seen that metal face plates will severely limit the Wemo's range, so I planned to replace the metal cover with one of these.
    20x40 32k IG vinyl, Hayward MicroClear DE filter, Sta-Rite IntelliPro 3 HP VS Pump, AutoPilot digital SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Wemo for pool light?
    Though they work, those outdoor covers are less than ideal. I use them for my cattle tank heaters, and my outlets usually only last 3 or 4 years in them. The equipment is still exposed to moisture in the form of condensation.
    Is there anywhere else you can install the WeMo switch in the circuit? Close to the breaker box? You could leave your mechanical switch in place and put the WeMo in series with it. That would make the old switch a winterizing/service shutoff.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I think this whole idea is really cool. If I get my POS light fixed I will so do this. Leave the switch on outside, and install a wemo by the breaker box. Thanks for the idea.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
