Results 1 to 8 of 8
Thread: Prologic with Superflo VS?
    Jul 2014
    New York
    34
    Just came across this thread. I have a 20k IG and would like to upgrade to basic automation, SWG, and VS pump. I am leaning toward the ProLogic PS4 w/ T-25 SWG and Pentair SuperFlo VS Variable Speed Pool Pump. I also plan to add solar at the same time. I would like the pump automation integration, but believe an Echostar would be overkill for my application. It looks like I can use one of the relays to trigger a speed on the Pentair like a 2-speed pump. The Hayward superflow VS doesn't even have those inputs for basic remote control.
    21' x 28" Grecian Vinyl Pool with fiberglass steps (@17k gallons) with Pentair SuperfloVS, Hayward sand filter with Zeosand, and Hayward gas heater. Pentair EasyTouch 4PSC-IC40 (Pentair IC40 SWG), and Screen Logic interface. 2 skimmers with main drain on the intake side and two primary returns with two low flow bubbler returns at the stairs. Aquabot pool cleaner. TF-100 Test kit.
    38,524
    Re: Hayward Pro Logic PS-4 vs. Aqua Rite - new pool install
    The Pentair Superflo VS will not interface with the Hayward ProLogic very well ... ideally you need to stick with the same brands. I am not clear if you can trigger multiple speed on that pump or not with a basic relay ... you might know more than me
    Jul 2014
    New York
    34
    Re: Prologic with Superflo VS?
    According to the manual, with a 0-30v signal you can trigger 4 different speeds. When the signal is removed it goes back to it's normal schedule. Based on that I am trying to figure out how I can program the pro logic to use one relay for solar heating and another for superchlirinate. I may need to call Hayward. There is one version of their Max flo VS that has similar functionality.
    I saw an old thread of someone planning on using a Rasberi Pi to figure out the Exhostar protocol and convert it to relays for use with the cheaper VS pumps.
    Why Hayward and Pentair haven't upgraded their automation to control the new pumps is understandable. I guess they don't think people with smaller pools will pay for automation. Maybe Next will come up with their own pool controller. Their Founder mentioned in an interview how much his pool controller frustrated him.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hayward makes Four variable speed pumps that will interface with the PS4. EcoStar with a 2HP impeller, the TriStar VS with a 1HP impeller (two models, one for hooking to a controller and one for stand alone). There is also a MaxFlo and Super pump VS available.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jul 2014
    New York
    34
    With the price of the pro logic plus aquaconnect, the new omnilogic may be the way to go since I can easily get ethernet to that area. May use Tristar VS without display. Will Call Hayward and confirm this will work.
    Oct 2014
    Elizabeth
    426
    The EcoStar and TriStar VS ND will both work with the OmniLogic.
    Hayward Pool Tech
    Jul 2014
    New York
    34
    It appears the Pro Logic will only turn the Super Pump VS on/off like a standard timer. The manual for the new Max-Flow 2302VSPND states that it will integrate with the Pro Logic and other automation systems with the proper software. I can't find corresponding confirmation of this in the Pro Logic manual though.
    The Max-Flow 2302VSPND is very new and does not appear to be shipping yet.
