Thread: Pentair Intellibrite 5G LED Light Lens Angle
    Apr 2014
    Eastvale, CA
    4
    Replacing my SAM light due to the common internal leak. Spent countless time with gaskets trying to stop the leak, just to find out it's the cord.
    Anyhow, I just received my intellibrite pool light to install and need to rotate the lens to the Narrow beam setting. They come assembled in the Wide beam angle.
    Now my question is, I understand Pentair always recommends a new gasket whenever removing the lens, will I need to replace the gasket on a new unit that hasn't been submerged? If so, not sure why they didn't include a spare gasket for this possibility. The install manual does not mention if the gasket must be replaced for this initial beam angle setting.
    Inground 19,275 gallon gunite pool with white plaster. Kidney shaped pool with an 8 ft. depth and 32 ft. long.
    Hayward swim clear cartridge filter, pump, and heater.
    Pentair halogen spa light.
    Pentair 5g intellibrite led pool light w/ color controller.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,023
    Re: Pentair Intellibrite 5G LED Light Lens Angle
    I had a similar situation so not quite the same. I changed out my incandescent bulp with a LED one a relatively new light. It had been installed for a couple of months when I made the switch.
    I did not use a new gasket, but I made sure the lubricate the exitsing one very well when I put it back together. I didnt have any leaks. I would suspect you would be fine as long as you lube the gaskets well with a silicone based lubricant.
    Divin Dave,
    Apr 2014
    Eastvale, CA
    4
    Quote Originally Posted by Divin Dave View Post
    So pool light gaskets are Ok to silicone lube?
    I may try that.
    Apr 2014
    Eastvale, CA
    4
    Just contacted pentair, they recommended to replace the gasket with the correct part number and to not use silicone?
    The gasket looks like the same as the sam light but has a different part number.
    Unfortunately the part number is not in stock anywhere locally.
    Wondering if the basic light gasket the sam uses will work.
    Sep 2014
    Fort Lauderdale, FL
    146
    Of course they want you to buy a new gasket. They're in the business of selling gaskets, lol...
    Sure, there's a little risk in reusing gaskets. But I'll be completely honest - while troubleshooting a non working light, I put a new bulb in my OLD fixture, and reused the OLD gasket. Cleaned, no silicone, and no issues (knock on wood).
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
