Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Ph through the roof
    May 2015
    Monroe/NJ
    76
    Ph through the roof
    Hi everyone- I'm new to the forum this is my first post.
    Inground gunite pool installed and opened 1 month ago. 33,500 gallons.
    I was warned that as the gunite "cured" for the first several months I'd have to add acid, but this is ridiculous.
    I've added 44 pounds of dry acid over the past 2 weeks and the Ph is still reading >9 on my home test, verified at pool store.
    It hasn't budged. I have to run my SWG at 85% 24 hours a day just to maintain the chlorine levels due to such a high Ph.
    CYA is at 40, calcium hardness at 200, salinity 3300, TA 100
    I have several questions:
    1) Is it unusual to have to add this much acid for a new gunite pool or is this par for the course?
    2) I have read other posts suggesting muriatic acid- is this a better option than dry acid?
    3) If so, where can I buy this stuff, can't find it online or at pool stores.
    Thank you for your help!
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    38,548
    Re: Ph through the roof
    You should switch to muriatic acid which should be in any pool store or hardware store.
    The pH has nothing to do with your SWG having to run so much. That at least partially due to your CYA being too low.
    What test kit are you using?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    That's your plaster curing. It will take huge amounts of acid early on, but it will slow down over the course of the next few months.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    If you are having to run the SWG 24/7 at that level then it is grossly undersized for your pool
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    38,548
    Quote Originally Posted by bdavis466 View Post
    That is true. I do not think the Nature 2 is anywhere near big enough for a 34k gallon pool.
    We would recommend a SWG that is rated for 1.5-3 times the size of your pool ... like up around 60k.
    And please take the minerals out of that thing to avoid ruining your new plaster.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Lowes has muriatic acid on the pool aisle in the garden section. Pool stores should have it too. Be sure to get 31.45% and not 15%
    May 2015
    Monroe/NJ
    76
    The Fusion soft 1400 owners manual states that this is good for pools up to 40,000 gallons....
    Please explain/elaborate. References? Thank you!
    Heat Pump
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It's good for pools up to 40k gallons based on running it 24/7. You don't need to run your pump 24/7, so getting a larger SWG allows you to cut pump run time while still making enough chlorine.
    One of the minerals is copper, which will build up in the water and can cause hair to turn green and the pool surface to stain.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    DFW, TX
    24,517
    May 2015
    Monroe/NJ
    76
    Thank you so much!
    Thankfully I haven't bought the 6 month mineral cartridge just the one month starter. I assume I can just take it out and it will run like a regular SWG? SO the pitch that the minerals help you to run the system at a lower chlorine level is just a pitch and (1) not worth the extra cost and (2) can potentially cause problems?
    Again thank you all for your help.
    Heat Pump
    May 2015
    Monroe/NJ
    76
    Quote Originally Posted by pooldv View Post
    Thank you!
    Thanks for confirming- I thought I was going crazy with the amount of ph minus I was putting in.
    I was starting to sound like a drug addict: every night I'm going home and dropping acid.
    Heat Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep...some pools just need some pH influence.
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Based on some previous posts it looks like the swg in the nature2 fusion soft produces about 1.25lbs of chlorine a day. That would mean you will probably have to run it at a fairly high output 24/7 to keep up with the chlorine demand of your pool. You might want to see if the builder will let you trade it in for a larger salt system since it's only a month old.
    Here's a thread from a couple years ago where their nature2 cartridge broke apart and stained their plaster.
    http://www.troublefreepool.com/threa...ac-Fusion-Soft
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Just want to point out about switching from dry acid to muriatic (hydrochloric) acid. Dry acid is sodium bisulfate. While it works, and is somewhat easier to handle than the liquid acids, the level of sulfates build up over time. Sulfates are known to damage concrete at higher levels, and can also damage the plates in salt cells.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    May 2015
    Monroe/NJ
    76
    Quote Originally Posted by jrs_diesel View Post
    Is there a way to decrease sulfates? Are they checked with typical water tests?
    It's a new pool- am I too late, or if I switch over now should I be okay?
    Thanks.
    Heat Pump
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I don't believe there is a cheap test available to test for sulfates. Probably could send a sample to a lab, but I don't know what level is considered too high.
    Easiest way to deal with it is to stop using the dry acid. Splash out and rain will bring the levels down over time.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No, they are not everyday tests at all. Not for pools. It's not a test you'd need to purchase. You can switch to MA any time you like, no problem.
    Essential Links:
    May 2015
    Wildorado Texas
    252
    Quote Originally Posted by Jim H View Post
    In my experience higher pH actually stabilizes Sodium Hypochlorite, it's the acid you're adding that's reacting it out of the liquor.
    May 2015
    Monroe/NJ
    76
    Quote Originally Posted by Red Neckerson View Post
    With your name and your signature, I'm not sure if I should take your comment with a grain of salt. (eh!?) I am not even sure I understand what you are saying- that by adding acid to bring it in to recommended range I am causing the chlorine levels to go down? Hmmm....
    Heat Pump
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    High pH in water inhibits the Hypochlorite conversion to Hypochlorous acid. This is what does the work. The presence of Cya in pool water let's FC be effective at a wider range of pH, up closer to 8.0... without it, the most general effective pH range for FC is about 7.2-7.5.
    Essential Links:
