Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Annoying "dirt" on pool floor HELP!
    May 2015
    Elkmont, Alabama
    12
    I have had this problem since last summer. The water is beautiful. I vacuum and everything looks great. A day later, I have patches of what looks like dirt on the pool floor. When I vacuum, it scatters and seems to dissolve in the water. Any ideas on how to get rid of this, or what it might be?
    Above Ground Pool
    14,000 gallons
    Sand filter
    38,275
    Re: Annoying "dirt" on pool floor HELP!
    Welcome to TFP!!!
    Can you post up a full set of test results?
    You could be seeing dead algae from a minor bloom (not always visible) ... or it could be pollen.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    If it just poofs up and disappears when it's touched it's likely dead algae. Light brown in color ?
    Test results and which test kit your using please !
    Jeff
    May 2015
    Elkmont, Alabama
    12
    I only have test strips and all appears within normal range on the strip. I have never had this problem with either of my pools until this past summer. After bringing my pool back from "swamp like" green after sitting over the winter, I did treat it for algae and the gray/light brown looking dead algae is all gone. This is darker brown like dirt. With it continuing to appear after closing and reopening the pool, I am really confused.
    Above Ground Pool
    14,000 gallons
    Sand filter
    38,275
    Sounds like a story we often hear ... it has been fine for years ... until it is not.
    Without good test numbers it is impossible to offer advice. If you want to take control, I highly suggest you invest in one of the Recommended Test Kits. Test strips are garbage.
    How do you chlorinate your pool? I am willing to bet your FC is too low for your CYA and you have an algae bloom starting.
    To truly eradicate the algae, you have to follow the ShockLevelAndMAINTAIN Process.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    +1 ^^^^^ to everything Jason said. It could also be when you last had the swamp you didn't get everything killed off.
    Order the test kit. I recommend the TF100 with the XL option. You will get more of the reagents you need to SLAM the pool.
    Jeff
    May 2015
    Elkmont, Alabama
    12
    I had a test kit when I put in an in ground pool 8 years ago. Ended up buying test strips, because they are quick and easy to read. When I moved to a house where an in ground pool was not possible, I installed an above ground pool. I have been using test strips, because my friends down the road have used test strips for 20 plus years and their pool is always beautiful......but he is also a chemistry teacher. I teach Kindergarten, so I guess that is where I am lacking (haha). Where is the best place to order a test kit? Also, is this test kit going to tell me what the crud on the floor of my pool is, and how to get rid of it? After dealing with it for over a year, I am weary.
    Above Ground Pool
    14,000 gallons
    Sand filter
    30,419
    No, but it will allow you to learn how to take care of your pool water so you don't have the problem anymore.
    This is a very serious pool forum with serious people giving serious, accurate answers. If you're weary we can help.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'm going to point you in the direction of these couple of articles from pool school. Give them a good read.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool
    Jeff
    May 2015
    Elkmont, Alabama
    12
    I have ordered the kit and the XL option suggested from the TFTestkits link. I will post results when I get it. Thank you for your help!
    Above Ground Pool
    14,000 gallons
    Sand filter
    38,275
    Great to hear! It will make the maintenance so much easier.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    When your kit arrives post up a full set of test results in this thread you started and will get you stared out on the right foot.
    You've done the right thing to help yourself out.
    Jeff
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Here are some more Pool School articles to read while you wait for your test kit
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    Use PoolMath to figure out how much to add.
    May 2015
    Elkmont, Alabama
    12
    I received my kit last night. Here are my results.
    pH 7.8
    CL 5.1
    FC .5
    CC .5
    Calcium 275 ppm
    TA 100
    CYA 45
    I have left the pool alone this week instead of trying to constantly vacuum the the stuff from the bottom of the pool. It is growing. As I said, it has been there since last summer, and no matter what treatment I use, how much chlorine I use, or what I do, it always comes back.
    Above Ground Pool
    14,000 gallons
    Sand filter
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Annoying &quot;dirt&quot; on pool floor HELP!
    Your water looks great! I would just keep vacuuming it out and hopefully it will go away.
    Are you sure it is not sand?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Elkmont, Alabama
    12
    I have thought about sand. A guy who works on pools, pumps, filters, etc. says that I would be able to feel the sand between my fingers if it were coming from the filter. I don't feel anything. The water is very clear. I just always have this stuff on the bottom.
    Above Ground Pool
    14,000 gallons
    Sand filter
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Maybe try cleaning it again. Then put a sock over the return to see what you catch.
    Lisa
    Fleck's Avatar
    Mar 2015
    Jacksonville, FL
    37
    FC is 0.5? You may be in for a short SLAM.
    AG 18k gal 28' circular pine straw collector, Hayward S220T, Power-Flo Matrix 1.5 HP
    Zodiac Ranger cleaner w/ Twister and a PoolSkim
    12" red, green, yellow, and white beach ball
    K-2006
    May 2015
    Elkmont, Alabama
    12
    Do the pictures look like algae to you?
    Above Ground Pool
    14,000 gallons
    Sand filter
  20. Back To Top    #20
    Jun 2012
    Rochester, NY
    247
    Quote Originally Posted by GJW View Post
    I had a similar problem the last few years. I had let my FC get too low. Looks similar to what I was getting, dead algae. When trying to vacuum it up it scatters are re-settles later. Or it doesn't seem to get picked up by the filer.
    You need to SLAM, most importantly Maintain. Keep that level up. Also, I set up a siphon with a garden hose directly to waste and pulled that stuff right out of the pool. I seemed to get better results at getting rid of that fine material.
    Shock level for you is ~18 for CYA of 45. I would get it there and keep it there to see if that helps clear it up.
    Good luck, keep us posted.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
