Results 1 to 14 of 14
Thread: losing fc
    Jun 2014
    gastonia/nc
    7
    losing fc
    Any help would be great. Losing 4.5 ppm FC over past few says after losing 2.5 for first couple weeks. CYA 70. CC 0. PH 7.6. FC at 5.5 end of day til one gallon of bleach bumps to 10. Vinyl siding. 18 x 36. Approx 19500 gallons. Clear and no algae. Any suggestions or clues i could use?
    RJT17
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    losing fc
    It's not uncommon to lose 2-3 ppm of FC per day.
    If I'm understanding your post correctly your losing 4.5 over a few days which would be fine.
    You can check if there is organics consuming FC by doing an OCLT Test.
    Jeff
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: losing fc
    Normal losses are aprox 2-3 per day. How sure are you of this CYA level? Did you use the pool store or strips, or your own TFPC approved test kit to get that number?
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    My apologies. I am losing 4.5 ppm daily. I know my CYA can still stand to come down but i had started at 120 after buying my house. Last summer on average i lost 3.5 ppm but i know that was attributed to the CYA being through the roof. I was hoping the 2.5 a day i was losing after the CYA would be the norm but again the past few days ive been losing 4.5
    RJT17
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    I used the TFPC kit
    RJT17
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    I used the TFPC kit
    RJT17
    38,271
    Re: losing fc
    As the CYA comes down, you will actually lose more FC to the sun.
    Sounds like there might be something lurking in your water. I suggest raising the FC level and Performing the Overnight Chlorine Loss Test.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: losing fc
    What has your sun and temperatures been during that time?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: losing fc
    I agree with Jason do the OCLT test to rule out if something is consuming FC. Post back your results and we can go from there.
    Jeff
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    Will do. Sunlight is directly on pool from sunup til 6ish. Then it gets a break from tree line. Temperatures outside have been pushing 90 and the pool temp is at 78-80. I will do the test tonight and post back. Thanks guys
    RJT17
    Re: losing fc
    As Jason and others have said, it can't hurt to run an OCLT just to rule out any nasty stuff, but I know that my pool consumes probably double the chlorine at 80 degrees or higher than it does at 60-70.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    Update. Did not lose any FC after overnight test. FC at 10. Same as last night. CC 0. Any other ideas or am I relegated to a gallon of bleach a day?
    RJT17
    Jan 2012
    7,306
    Re: losing fc
    Just a thought- are you sure of the strength of your chlorine? Some cheaper chlorine is less than the standard 8.25 % most common now. Dollar stores and the like sometimes have some as low as 3%. That's not a bargain y'know? Fresh chlorine is the strongest, old chlorine or chlorine exposed to outside elements loses potency.
    Yippee
    Jun 2014
    gastonia/nc
    7
    Re: losing fc
    Yes it is 8.25. I buy walmart brand only and one gallon jacks up my ppms 4.5 each time. I keep the bleach in my laundry room on my shelf to avoid evaporation from heat. Thanks for the thought. Im just going to monitor for another week and see if this is just my fate this summer
    RJT17
