Results 1 to 13 of 13
Thread: Stabilizer at walmart?
    Apr 2015
    Jax, FL
    36
    Is the stabilizer at walmart any good to purchase?? Or should I be going to the pool store for this? No ingredients listed on the bag so couldn't tell if it was straight CYA or if there were any unwanted additives mixed in. Thanks!
    Legacy AG soft-sided pool (13'x21'x52"), 7,400 gallons I think?? (not sure how to determine this for sure...I've used poolmath but the pool is slightly irregular we have found), Pooline sand filter, 1 horsepower/1 speed pump, Pool installed within the last week and finished filling 4/26/15, TF-100 test kit, Intex Krystal Clear SWG, & Splash a Round Pools Leisure automatic vac. 1st time pool owner wanting to avoid the pool stores!
    38,483
    Re: Stabilizer at walmart?
    Many people find that the Walmart dissolves easier than other stabilizer. Check the ingredients ... it should be near 100% cyanuric acid.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    The "bag" you say?.....I purchase mine in a 4lb. plastic cylinder looking jug there with a purple top. Says Stabilizer and conditioner on the front.
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by woodyp View Post
    Stabilizer comes in a jug. Are you sure it's stabilizer and not a bag of *Shock*?
    Apr 2015
    Jax, FL
    36
    Just got it home - it's a jug and says 100% cyanuric acid. Guess we will see how it does - thanks!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    thats what I use. works just fine.
    Divin Dave,
    May 2015
    Savannah, GA
    62
    I bought the one from Walmart too. It was a 4lb jug. Pool installs Thursday I'll be using it probably Friday or Saturday once pool fills. Says 100% on mine too.
    24 ft round 52 in Evolution CLX 13,000 gal, Hayward S180T pump sand filter & 1 hp Power-flo Matrix single spd, TFP method, Borates Added, Taylor K-2006 Test Kit (Rincon/Savannah,GA)
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    That's what I buy. HTH brand. Works great.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good the hear. Last time I got it at walmart it was 96%
    Essential Links:
    bulldogz400's Avatar
    Jun 2014
    Las Vegas
    128
    Same. Definitely took some time to dissolve in the sock placed in the skimmer, but it did the job just fine and was much cheaper than the pool store (NPS) right next door.
    IG gunite 32 x 18 on a bachelor budget! Click Here To See
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    Bought the HtH jug at Walmart last week. 96%. Dissolved nicely.
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I think the word is out here in OK, i went to both walmarts in town and no HTH CYA left on the shelf..... Had to get the more expensive from lowes...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, 96% is fine. If you do the math the nig name Pools Store is still WAY high with their 98%.
    Essential Links:
