Thread: Air bubbles strainer basket
    I checked the basket its tight, but could it be this coupling? if so how do i take this off, it seems like its glued on, I can't figure a way to undo this coupling? Is it even possible? Attaching a picture..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Air bubbles strainer basket
    As long as the water level in the strainer is above the inlet to the pump a little air in the strainer is not a problem and will not affect the pump or the pumping rate. I would not let it bother me unless there is so much air that it gets in the pump suction - then you would have a problem.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    so it doesn't really matter if I have a few air bubbles in the strainer basket and some air bubbles coming out of my return jet as well?
    Bel Air, MD 21015
    Quote Originally Posted by precator View Post
    You would have to cut the pipe and unthread the coupling. But there are several things to check first. I would remove the pump lid, taking the opportunity to clean the basket, and replace the lid making sure to use o-ring lube. You may also have the ability to purge air from your system at the filter, which you should try also. There are some ways to check the pipes in your system for leaks, just search the forum for ideas on how to do that.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Sorry it took so long to answer, but no a few air bubbles in the strainer basket and some coming out of the returns is not going to hurt any thing. You might replace the gasket (and the lid itself if it looks bad) under the strainer basket lid and make sure to clean the lid on the top and the basket holder and use gasket lube on the new gasket. A dirty, dried out, or worn out gasket will give you leaks. But if a new lid and gasket does not stop the leaks I would not worry about it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Most likely any air leaks are coming from the drain plugs or the pump basket lid gasket. Even a hairline crack in the gasket or a blade of dried grass stuck under it can do it.
    You can check the plumbing by covering suspicious areas with shaving cream. If the bubbles go away, or you start seeing foam in the basket, or you see the cream being sucked in somewhere, you're on the way to finding it.
