Thread: Liquidator Air Leak
    Liquidator Air Leak
    So I am getting air into my suction pump and I think I know what the problem is. one of my parts in the liquidator has broken a bit. Does anyone know what I can do to fix this? Can I temporarily somehow close the holes I made to my liquidator to see if this is really the problem? I am attaching a picture of what I think is wrong
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    30,431
    Re: Liquidator Air Leak
    Is that penetration on the suction side of your system?
    yes suction side.
    Bel Air, MD 21015
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    If you call HASA they will send new parts at no charge.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Does anyone know the exact size of that fitting in both ends? Home depot has a bunch of nylon barb fittings that may be do trick.
    Bel Air, MD 21015
