Results 1 to 8 of 8
Thread: High PH
    Apr 2015
    Chesterfield, mi
    62
    High PH
    Is it normal for PH to creep high daily? I lower it just about daily.
    34x18 doughboy (desert springs) above ground. Has deep end, but don't know depth yet. Pool came with house (first season). 22in sand filter (250lbs sand)with 1.5hp two speed pump. Pentair MiniMax ch 200m heater.
    440 gallon Emerald spa. Currently a 3.6hp, 2 speed, 46y, 240volts motor. Changing to a 3hp, 2 speed, 56y, 240volt motor.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: High PH
    How high is it?
    Can you post a full set of numbers?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: High PH
    pH rise is largely dependent on how often the jets are running, how much air you're introducing when the jets are running and mostly then your total alkalinity (TA). As Azgirl said:
    Isolated Spa - 345 Gallons
    Apr 2015
    Chesterfield, mi
    62
    Re: High PH
    Fc 2
    cc 0
    ph >8.2
    ta 60
    cya 20
    We are in out several times a day. Kids, what are gonna do?
    Feb 2014
    Central Minnesota
    5,080
    Re: High PH
    TA looks like it's approaching a normal amount for a spa. In mine, I let the TA get to 40-50 and my pH rise slows by quite a bit. Higher than that and the pH rise is very quick, depending on how much I run the jets.
    Let the TA live in the 40-50 range... before adding baking soda to bring back to 50-60. You'll have less pH rise, less acid use.
    My fill water is 120 TA so I know the pain after a new fill of constant acid additions.
    Apr 2015
    Chesterfield, mi
    62
    Re: High PH
    Good advise. I will have to test my fill water as well.
    Feb 2014
    Central Minnesota
    5,080
    Re: High PH
    If you still struggle with pH rise at 50 TA, you could add borates to attempt to stabilize pH some, but be sure that TA is 50-60 before adding borates. You can buy pH balanced borate solutions such as Gentle Spa to add borates easily. A cheaper but much more of a hassle method of adding borates is using borax and... acid. Because of the low volume of spas, it's not that expensive to add borates as a pH balanced product. Pools on the other hand, it's much more expensive to add pH balanced borates, so in pools people tend to add borates with the borax/acid method.
    Apr 2015
    Chesterfield, mi
    62
    Re: High PH
    I've read about borates and intend to add to pool and spa. I was looking at the boric acid at Dudadiesl.
