Thread: 1 year old AG 16x48 Intex ultraframe
    Jun 2014
    Elizabeth, IN
    14
    Last year was my first year with a pool. I learned a lot but it's been awhile. It's so easy to forget. I'll be taking notes this year for next year! We are reopening our pool. We have only filled it with water and turned the filter on. I have not added the salt or any chemicals yet. We have trees with white blooms around the pool causing a lot of debris. There is some white build up in the pool besides the petals, I'm wondering if this is pollen or whatnot from the trees? We ended up leaving the pool up all winter and uncovered after the pool cover caved in (lesson learned). We drained 99 % of it and refilled. What is my next step? I tested all the levels. Do I add the salt first and turn on the swg? Or do I start with the other levels? We have very hard water and I get ALOT of build up in the swg cells so it's a chore to keep up with but I was eventually able to keep in maintained last year. Here are my levels. TY for any and all Advice!
    Salt - did not register on test
    Chlorine- 0
    CH - 125
    TA - 220
    CYA- 0
    PH - 8.2
    - AG 16x48 Intex Ultraframe 5061 gal
    - Krystal clear cartridge filter pump 1200 gph
    - Intex Krystal clear salt water filter
    -Stephanie- Louisville, KY
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1 year old AG 16x48 Intex ultraframe
    Welcome. May I ask what test kit are you using? Based off of your results you posted your PH is to high it needs to be lowered. No FC is not good and no CY is not good. If you can let us know what test you are using it will help us to direct you on where to start.
    Edited to add I see you have the TF 100 from reading your post from last year.
    Jason has guided you in the right direction.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,463
    You should lower the pH into the 7s and get 2ppm of FC in the water and maintain it there.
    Then get some CYA dissolving in a sock, target around 50ppm and start maintaining the correct FC level for that CYA (FC/CYA Chart).
    After a week test the CYA and add more to hit around 70ppm for your SWG.
    You can add the salt at any time, wait at least 24 hours to turn on the SWG ... and you will likely need to supplement the FC with bleach until the CYA bank builds up.
    Jun 2014
    Elizabeth, IN
    14
    TY so much
    Perfect advice. Thanks a lot!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    Welcome to TFP!
    First thing to write in your notebook is to never let FC fall below the minimum level for your CYA level on this Chlorine CYA Chart. Not even for 1 day, if you do algae can start growing and you will need to SLAM.
    Here are some intro Pool School articles
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here is the Water Balance for SWCGs pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    Use PoolMath to figure out how much to add.
