Thread: How do you store your vinyl winter cover
    May 2013
    Ontario, Canada
    63
    I have a blue plastic bucket with a lid that I store by 18' x 36' vinyl winter cover in between may - October. I add a little algaecide, fill the drum with water and a little bleach.
    How do you store your winter cover?
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    Jun 2012
    western NY
    1,562
    Re: How do you store your vinyl winter cover
    mine is not vinyl, it is a polypropylene plastic tarp material. I lay mine out on the driveway and hose it down real good to clean it and let it dry. I fold it into halves until the widest part is about 2' wide then I roll it up and store in on the top shelf in the garden shed
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Mine just goes in the carrying bag folded up. Bag goes in the basement. I make sure to dry the cover in the sun, draped over the fence before storing.
    Isolated Spa - 345 Gallons
