Thread: New Pool Owner--Questions about CYA
    Apr 2015
    Phoenix, AZ
    5
    Hi Everyone,
    I am a brand new pool owner and learning the ropes right now. I am located in Phoenix, AZ. I have read Pool School a few times and am going to order a TF-100 kit.
    In the mean time I have been going to my local pool store to get the water tested (according to everything I've read here, this is a bad idea).
    The CYA levels are above 100. Around 120. I mentioned this to the pool store, but they said here in Phoenix that CYA is always going to be higher compared to the rest of the country and not to worry.
    Can anyone confirm this is correct? I am especially interested to hear from other Phoenix residents.
    Thank you!
    25,000 gallons, plaster, sand filter, in-ground
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Pool Owner--Questions about CYA
    While it's true that in hotter, full sun climates, CYA levels should be higher, that's a bit higher than recommended. See Chlorine/CYA Chart
    How high your CYA should be depends on your type of chlorination as well. Bleach or SWCG?
    When you get your kit, dilute your pool water 1:1 with tap water to get a more accurate CYA reading. Multiply the result by 2.
    Isolated Spa - 345 Gallons
    Apr 2015
    Phoenix, AZ
    5
    Thanks for your advice Joel!
    I have bleach chlorination.
    Once I get my kit, I will test everything and take it from there.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Im sure thats what the pool store said and Im sure they are wrong.
    Its true you may need 'slightly' more CYA because of the heavy sunlight and UV in Phoenix, but 120 is not ok.
    Divin Dave,
