Results 1 to 18 of 18
Thread: Help size my pool!
    May 2015
    NY
    12
    Help size my pool!
    Hello,
    I've been struggling with my in-ground vinyl pool since I purchased my house a few years ago.
    One of the biggest problems I've had over the years is I don't know how big (gallons) my pool is!
    There was no documentation on the pool left from the previous owner.
    All I have for accurate measurements is the land survey that was conducted when I purchased the house.
    I'm not sure how deep the deep end is but I'm 5'10 and if I stand flat foot in the deep end and extend my arms straight up I cant touch the surface of the water.
    Can anyone assist with sizing my pool with the attached measurements?
    Some pool store college kid guestimated it to be 45k gallons.
    I'm trying to avoid pool stores this year as much as possible
    Any help would be appreciated.
    Thanks!
    38,235
    Re: Help size my pool!
    Welcome to TFP!!!
    We really need the depth profile, but assuming it is 8' to around 3.5' ... I would put it around 26k.
    What are you talking to the pool store kids for? We can help way more than he can
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    I agree of course, plenty of knowledge here. 45k is too high for that size for sure. No worries, we are here to help if you're interested, just let us know.
    Essential Links:
    Nov 2013
    Central Texas
    113
    Use your pool pole starting in the deep end to figure out the depth of the pool. Your going to get wet doing this or maybe if you have a large raft you could stay dry. Submerge your pole at the deepest part of the pool and mark the pole or use a rubber band and adjust it to the water level on your pole. Then take a tape measure and measure the distance from the end of the pole to the marked area. Do this every few feet and record the numbers.
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    May 2015
    NY
    12
    I'm traveling for business next week but plan to open her up on Memorial Day (fun!).
    I have a mesh loop lock cover on my pool. Every year when I open it it's completely green.
    Typically I vacuum to waste to get all the settled green stuff out. Even though the pool has a ton of water in it right now I usually need to add the garden hose in it to get it to the correct level after all the vacuuming to waste.
    Then I add the $300+ worth of chemicals the local pool store kid tells me I need to purchase.
    What would be the suggested course of action this year?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Buying a good test kit should be at the top of the list. Second would be a bunch of bleach. Have you read through all the pool school articles?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,235
    Well ...
    Have you discovered Pool School yet? While on your trip I would start learning with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    You should also order one of the Recommended Test Kits soon so that you have it by when you want to open. The TF-100 is the best option and add the XL option to get free shipping since you will need it to clear the pool.
    When you open, circulate for an hour (after vacuuming if you want) and then run a full set of tests to know what you need to adjust.
    With algae, you will have to SLAM the pool. Check out these:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    ShockLevelAndMAINTAIN Process
    I can nearly guarantee you will spend less than $300 clearing up the pool including the cost for the test kit
    May 2015
    NY
    12
    I already have a TF-100 test kit on order. It should arrive next week
    I've read most of the Pool School stuff already. It's probably a good idea for me to re-read it a couple times to get more familiar with all the lingo. I look forward to not visiting that dam pool store this year!!
    Thanks
    Pinch
    38,235
    Fantastic!!! Sounds like you are off to a good start
    It is actually a little easier to understand once you get your hands on the test kit and start "doing" instead of "reading".
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP! Congrats on taking control of your pool!
    Please update your signature with your pool info as shown here.
    May 2015
    NY
    12
    A little update of where I'm at.
    I'm going with jblizzle's guesstimate of 26k gallons
    Took my cover off on Monday and it was pretty much a swamp. I vacuumed to waste as best I could, refilling to pool as needed.
    FC is zero.
    I then tested the CYA and it was around 80.
    I did a few partial drains/refills.
    Re-tested CYA and I'm at 40
    Next I tested the PH and it was pretty low, lower then the 7.0 bottom reading on the tester.
    Last night I added 2 boxes of 20 Mule Team Borax
    This morning I tested PH and it was at 7.4
    I then added 4 gallons of bleach (8.25, 121).
    The PoolMath calculator request 5.1 jugs but I only had 4 on hand.
    However I did add 1 gallon of liquid chlorine that I had from last season (not sure if that was a good move or not)
    I know I probably should have waited till tonight to add the bleach but I really didn't want to waste another day with no chemicals in the pool.
    Fingers crossed!
    38,235
    Did you get the test kit delivered yet? You now need to maintain the shock FC level to follow the SLAM process.
    May 2015
    NY
    12
    Yes, yest kit received.
    I will grab some more bleach on my way home from work tonight and test FC
    Planning to keep FC at 16.
    Thanks for the help!
    May 2015
    NY
    12
    Just an update (and more a way to help me track)...
    Tuesday night around 8PM I added 1st dosage of bleach to get to FC 16 (5 gallons of bleach)
    Wednesday night around 8PM tested FC at 3, added the recommend dosage of 4 gallons of bleach to get back to FC 16
    Thursday night around 8PM tested FC at 7, added the recommend dosage of 3 gallons of bleach to get back to FC 16.
    Surprisingly this morning at 7AM (11 hours after adding bleach) tested FC at 16.
    The water is pretty clear with a light green tint in the deep end. It definitely needs a good vacuum job which I'm planning to do tomorrow morning.
    So to do a quick cost analysis:
    12 - gallons of bleach @ $2.84 ($34.08)
    2 - 20 Mule Team Borax @ $3.99 ($7.98)
    Total money spent on chemicals so far this season: $42.06
    This time last year I dropped over $400 at the pool store!
    38,235
    That does not sound like the SLAM process to me. With only one test a day. Did you pass the 3 criteria to stop? Did you test the FC at night after the chlorine addition ?
    May 2015
    NY
    12
    Hey jblizzle,
    I don't believe the SLAM process is complete either... I'm just surprised at how easy it's been going.
    Much easier and cheaper then previous years.
    I was a bit surprised this morning though at the FC level.
    It will be interesting to see what it's at tonight.
    38,235
    Ah, ok. Keep it up.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    Keep SLAMming. Also, no need to open to a green pool each spring. Open earlier and close later. Algae doesn't grow below about 50 degrees. And you can also pop the cover open on a corner and add some bleach and stir in between. We are 2 for 2 opening to crystal clear water in the spring...just a pile of worms and a few leaves at the bottom.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
