Results 1 to 8 of 8
Thread: Please advise! What size pump for my setup?
    Jul 2014
    Harrison Township, MI
    41
    My motor went out, so I am looking at either replacing the motor or buying a whole new pump. I currently have a 1.5 horsepower Hayward super pump that is single speed. I would love to get a dual speed setup so it will be more efficient. I am confused however, on exactly what size motor/pump I need.
    My pool is approximately 30,000 gallons and it has two skimmers and a main drain. One skimmer is about 35 feet away from the pump, the other one about 55 feet away, and the main drain probably about 55 feet away from the pump. There are four return lines. I have a Hayward S244T filter and a Hayward gas heater.
    I do also currently have an auxiliary pump that is connected to a jet in the pool that the previous owner used a dolphin robot with. There is also a water slide that has a water spigot integrated into the current system, but I did not use it last year so I'm not exactly sure how it works.
    So, do I just stick with the 1.5 horsepower motor? If I do decide to replace just the motor, can I replace it with a two speed motor even though it is only a single speed right now?
    I've attempted to attach some pics. Any advice you can give me will be greatly appreciated!
    20x40 IGP w/ vinyl liner ~ approximately 30,000 gallons ~ Hayward 1.5hp pump ~ Hayward S244T Sand Filter ~ Hayward Gas Heater ~ 1 drain, 2 skimmers, 4 returns ~ Protect-A-Child Fence ~TF-100 kit
    38,540
    Re: Please advise! What size pump for my setup?
    Sure you can replace it with a 2-speed version ... and either buy an end cap that has a switch installed or add an external switch to manually select the speed.
    You should match the HP and the SF of the new motor to the old motor (well, actually the product of the 2).
    Make sure you get a new shaft seal as well.
    If you wanted to go to a smaller 1HP motor, you would also need to replace the impeller.
    One thing we need to check though ... is your current pump wired for 115V or 230V? Most 2-speed motors only come in 230V.
    Jul 2014
    41
    So, if I keep it at 1.5hp, I won't have to change anything?
    Should I stick with a 1.5hp?
    How do I figure out if it is currently 110 or 230?
    BTW, I have NO idea why my pics are up-side-down! They are right side up when I upload them!
    J
    38,540
    Sticking with a 1.5HP is fine and the only thing you would have to do is hook the new motor up and adjust some of the wiring.
    What do the wires look that that ran to the motor? Although more importantly, what kind or circuit breaker feeds the pump motor.
    Jul 2014
    41
    Here's what the writing looks like:
    The circuit breaker is a single breaker. It's either 20 or 30 amps.
    What else do you need to know?
    38,540
    If it is on a single breaker, the obviously the motor is 115V, which makes finding a 2-speed motor a little more difficult, but I think they exist.
    Jul 2014
    41
    Bummer. Maybe I should just stick with a single speed? What does it take to switch it over to 230V?
    38,540
    If the wires run directly from the breaker to the pump: Another slot in the breaker box ... and relocating the neutral (marked with tape) to another hot line. Although I am not 100% that is acceptable as far as codes are concerned.
