Hello, sorry if this has been covered.
I have a 12 year old pool that has needed both pump motors replaced in teh last three years. Now the PVC at the inlet is leaking on both teh filter & PSS2000 cleaning system inlets. They have a kind of "caulk" like material that is flaking off. After some searching I think/hope they are the screw type as opposed to glue type but would appreciate input as to how to proceed.
I cut of & replaced the bottom of the PSS distribution system after it broke off where teh toop cover attached so have no problem cutting/glung together the pvc if that is necessary. I just want to fix it properly/
Thanks
Thanks
