Results 1 to 8 of 8
Thread: Burning alot of chlorine
    Apr 2015
    Mesa, AZ
    13
    Arizona, 17K Plaster
    Current levels
    FC: 6
    CC: 0
    pH: 7.8-8.0
    CH: 425
    TA: 120
    CYA: 50
    Pool is clear everything seems to be fine. 10% Liquid Chlorine is fairly cheap here in Arizona (5.50 two gallons) so that's what I use because Im not sure I trust dollar store bleach (yet). Any way, I feel like im burning a lot of chlorine. If I don't check and adjust every day it will drop to 3ppm. Im wondering if I should up my cya to 60-70, to help prevent loss? Also is there some kind of calculation to where I can say ok, I need to add 1 cup per day?
    17k IG Plaster pool (2004), Pentair V3050 Intelliflo(2015), Hayward C3030 325cf cartridge filter
    Zodiac G3, TF-100 test kit w/ SpeedStir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Burning alot of chlorine
    Every pool will vary, but based on your location, you could ease your way up to 60 ppm CYA and would have better results with chlorine loss. Most pools will lose 1-3 ppm per day with no bather load. Mostly dependent on CYA level, location and how much sun each day.
    Isolated Spa - 345 Gallons
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Before you bump the CYA up lets make sure there is nothing in the water consuming your FC.
    Tonight conduct a Overnight FC Loss Test (OCLT).
    Still, in AZ a 3ppm drop during the day is not that unusual.
    If you pass the OCLT then yes, bump the CYA to 60 and for now I would immediately bump your target FC to 7 - 8 so that at no time with loss you go below your minimum of 4.
    Support the site
    38,532
    We generally recommend testing and using PoolMath to calculate how much bleach you need to add to get back to your target.
    The most important thing is that you never let the FC level drop below the minimum listed for your CYA in the FC/CYA Chart.
    I would expect that you have to add about 1/2 gallon of 10% everyday.
    Apr 2015
    Mesa, AZ
    13
    Pool math....using it every day!
    My CC has been coming back 0 so I don't suspect anything is eating it, I suspect burn off. Ill do an OCLT tonight!
    Feb 2014
    Phoenix, AZ
    51
    3ppm / day here near 32nd and Shea and 1/2gall 10% each morning - btw my CYA is up to 70 now although I would prefer it be down at 60.
    I sometimes think adding all that bleach is excessive but my kids have been in the pool for 60 straight days so far this year.
    20 gallons of bleach : $56
    60 days of swimming : priceless
    Cardano
    20k IG PebbleTec w/ STA-RITE PE5E-182L 1HP and Zodiac Polaris PB4 for Polaris 380 vacuum / Hayward ProGrid DE4820 Filter / TF-100 but I havent broken down and gotten a speed stir yet
    carpainterinaz's Avatar
    Apr 2015
    Tempe az
    27
    3ppm / day doesn't seem that excessive. I'm in Tempe and have a 7900 gal pool. Currently my cya is a bit over 50 and I'm adding just under a quart of 10% daily so my fc doesn't drop below 4. I test and add in the evening around sundown. Been on the tfp method for 3 weeks now. 2-3 ppm fc seems to be my daily avg loss, and Iv been keeping a daily log since I started.
    7900 Gal custom built in ground beach edge pool
    Custom matched Montego Bay color mini pebble interior finish with abalone shell
    Pentair variable speed pump and cartridge filter
    4 main pool returns and 3 24" sheer descent water falls
    3 Pentair intellibrite led lights in the pool and 2 matching landscape lights
    Apr 2015
    Mesa, AZ
    13
    My OCLT came back good as expected. I bumped the CYA to 60. Ive been using actual 10% chlorine, which is reasonably cheap. I need to find some good dollar store bleech that's 10%. Cardano and Carpainterinaz...have you found a good source?
