Thread: pump cover necessary for Pentair Intelliflo?
    So I just upgraded to a new intelliflo, (its awesome btw) and I'm wondering if I need to have a "cover" for the pump itself. The installer said the real killer of pumps is heat, and sun. My pump gets a fair amount of sun and is close to the brick which i'm sure radiates a ton of heat as well in the summer. Is it necessary to cover it? Will that just increase the heat if its covered?
    Here's a cover I found.
    http://www.amazon.com/gp/product/B00...f_rd_i=desktop
    22k gallons
    White Plaster
    Jandy DE filter
    inline 320 Chlorinator
    Polaris 280
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: pump cover necessary for Pentair Intelliflo?
    The primary failure mode for a VS pump is first and foremost a power surge so I hope you installed a surge protector with the VS. The second type of failure that affects all pumps is a seal leak. Most people ignore a small leak but what happens is the bearings get wet and start to rust and then it isn't long before the bearings fail.
    As for heat, that could affect the drive over time but a cover like that seems as though it would trap heat from the drive itself. I think a better solution would be a shade awning or sail over all the equipment.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Please update your location in your profile.
    Not sure where you are, but it is plenty hot here. Not at the moment unfortunately. My pump has run nearly 24x7 for 3 years. Mostly at 1100rpm to skim the massive amounts of stuff all our trees throw in the pool and sometimes at 1950 rpm to run my solar panels. No cover and so far so good!
