Thread: Vacuum after opening
    Feb 2015
    Grand Rapids MI
    53
    We just had our pool opened this past weekend. They did a vacuuming when they opened it but now all of the water is clear and the sediment has dropped to the bottom. My question is when I vacuum all of it out should I vacuum as normal or should I vacuum to waste? If I vacuum to waste I will lose a lot of water correct?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Vacuum after opening
    Quote Originally Posted by jandersen13 View Post
    Yes. If there's heaps of stuff, you'll clog the filter. But if it's just dust, that's what the filter is for.
    Feb 2015
    Grand Rapids MI
    53
    Thanks Richard. I tried at first tonight to just vacuum as normal using the filter as I thought it was not a ton of stuff, just pollen and some dirt. I have 2 skimmers and plug one to get the best suction out of the other. The suction was ok at first but then pretty much stopped. I went to the pool pump and cleaned the skimmer there and then the suction came back for a bit. But the same thing happened and I noticed when going back to the pool pump skimmer the water wasn't full and it was pulling in air it seemed. I then decided to backwash the filter and get pressure back to normal. I did that and thought to vacuum to waste. The suction started off good but then did the same thing where I lost it and the pump skimmer wasn't full of water completely and seemed to have air in it.
    Any ideas what's going on here? I can vacuum for a minute and then I lose suction pressure. Am I doing something wrong?
    Richard320's Avatar
    Jan 2010
    19,007
    You have an air leak somewhere. My guess would be the vacuum hose itself. It only needs a pinhole.
