Results 1 to 10 of 10
Thread: Reduce Very High Chlorine
    Jul 2014
    Atlanta, Georgia
    6
    I had a solar pool cover on the last four weeks and inadvertently kept the SWG running at 60%. I am ready to swim and tested yesterday and the FC is very high. I decided to go to Leslie's to get second opinion on the free chlorine. The free chlorine is very high at 25 and I need to get it down because we have a pool party on Thursday. I have the SWG turned off so it is not producing any chlorine. I don't think the FC will reduce all the way to 4.0 by Thursday by itself. I would like to chemically fix the high free chlorine.
    Leslie's wanted me to buy their Chlorine reducer but after being part of this forum I balk and doubt whatever they tell me. What is the best/quickest way to reduce the free chlorine? The pool calculator does not tell me what and how much to use. Does anybody know how much I should use and are there any adverse effects I need to plan for?
    FC = 24
    PH = 7.5
    TA = 80
    CYA = 70
    35,000 Gallon Inground Pool 20' x 40' / Vinyl Liner / Pentair IC40 SWG / Hayward Sand Filter
    First time pool owner in 2014 but pool is about 6 years old
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Reduce Very High Chlorine
    Shut off the SWG and leave the cover off. You'll lose a lot of FC when the sun hits the water.
    Also, with 70 CYA, shock level is 28 and you're already below that. It's safe to swim right now. Might be rough on swimsuits though.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    At this point just let the FC drift down on it's own. At FC of 24, you are below the recommended shock (safe to swim up to) level of 28 for your CYA of 70. Additionally, the higher FC will be brought down further by the bather load during your party.
    Sounds like you should sit back and enjoy the party.
    Thanks Richard - I should have just waited for the expert!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by Pool Tool View Post
    Nope, not at all. You were probably typing when my reply went up. It's going to get crazy here really soon, and the number of new threads every day will be so mind-boggling that us "experts" won't be able to keep up. We need your help. You came up with the same answer as me, that shows you understand. Don't wait for us, jump in!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by timothyd9 View Post
    CYA = 70
    I agree with everyone else about just letting it drift down, but your comment I cut out concerns me. With CYA 70 in SWG pool 3 is your absolute minimum. Planning a pool party to start with 4ppm may be flirting with disaster. A normal target for your CYA level is 5 and with a pool party I might even want it up around 8 or 9.
    In your nice Hot-lanta weather it should drift down fine.
    Support the site
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Thats an interesting point, when having a big party, do people pre-load with a bit more chlorine than they need in general? is that recommended? it makes sense.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by umpalumpajay View Post
    Mnay do. I'm willing to admit I "borrowed" the idea from Richard320
    Support the site
    38,301
    Even with my SWG, I often bump my FC up with a bottle of bleach before heavy use.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Before a party, I definitely up the FC. My kids know the NO PEE IN THE POOL policy, but other kids and adults consuming adult beverages sometimes do not. My minimum FC is usually 3 depending on time of year, current CYA. Target is 5. I'll bump it up to 6-8 maybe even 10 before a party, depending on expected guests and my "ability" to test the pool after the party.
    Isolated Spa - 345 Gallons
    Dec 2014
    West Hills, CA
    157
    i'd thought about doing that, we havent had a big party yet, but i'll pop it up from 5-6 to maybe 8 when i do. lots of kids = better safe than sorry.
