Thread: Do I have to SLAM when opening?
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Peeked under pool cover, water looks as clear as I left it. If all is really well when I remove the cover and the needed water, do I just get it back to my normal levels of do I have to SLAM?
    Was told I must shock pool but since I don't use their method, I didn't know if it was necessary.
    Also, is pool safe to swim in right off the bat. Naturally, the kids are just begging to open and it's gonna be tempting them to get right in.
    HAPPY SPRING! It was a long, cold winter. Happy to be asking this question. My first pool opening! Yea!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Do I have to SLAM when opening?
    Can you post a full set of numbers?
    If your pool is crystal clear I don't think you will need a SLAM.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Why SLAM if nothing is wrong?
    Once it's open and the water is well mixed get a full set of tests done.
    Adjust pH first. The add chlorine to get to a known number, lets say 10 and test again in 30 minutes to an hour and see if the chlorine is holding. If not, you may need to SLAM.
    I would definatly do a Overnight FC Loss Test (OCLT) to verify nothing is hidden in the water.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I second Tim's advice.
    Essential Links:
    Aug 2013
    Pennsylvania
    158
    Opened pool, added water and first test results. Seems to good to be true...
    FC = 2
    CC = 0
    TC = 2
    PH = 7.6
    TA = 100
    CYA = 35
    I think I might bump my CYA up in the 40's this summer? Kept it like 30 last year.
    My neighbor just said "aren't you gonna shock your pool?"
    MermaidMama
