Results 1 to 7 of 7
Thread: Newbie trying to open pool - sand filter gauge seems stuck
    May 2015
    Ottawa
    11
    Hello. We put our pool in mid summer last year, so this is my first time attempting to open it. Everything seems to be going well, water is nice and clear. Filled it, got the pump and everything up and running, put some super shock in it and thought I was golden. I had a quick look at the pressure gauge on the sand filter, and regardless of whether or not the pump is on, the gauge is wrapped all the way around and is stuck on the stopper thing. Can I assume the gauge is bad? I'd call the guy who installed the pool, but he is impossible to get in touch with, so I've given up on him. Have a look at the pic;
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: Newbie trying to open pool - sand filter gauge seems stuck
    Welcome to TFP!!
    Sorry you found us under these circumstances.... Yes, the gauge is bad.
    You really want a quality glycerin-filled gauge that doesn't go a high as your old one. 6p PSI just doesn't give the detail you want most of the time. 30 is fine for pool use
    Check here
    Witht he pump off you should just be able to unscrew the old one and screw in the new one.
    Support the site
    May 2015
    Ottawa
    11
    Awesome, thx for the quick response, I really appreciate it. Am I OK to run the pump while I track one of these down and get it installed?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by cdooer View Post
    Yeah. No problem running it like it is. You just won't know when it needs to be back washed until you replace the gauge.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    Ottawa
    11
    Thx again folks.
    May 2015
    Ottawa
    11
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!!
    Check here
    I just bought one of these gauges, and noticed that it says its freeze protected down to -4 F. It gets colder than that here in Ottawa on a regular basis in the winter. Should I just play it safe, and take it out and bring it in the house and store it in the basement during the winter? I do this with the pump already.
    24' Radiant Metric semi-in-ground pool w/Hayward SP5715W Pump. Newbie...I've been a pool owner for less than a year...go easy on me.
    Dec 2014
    Riverside California
    482
    Sounds like a very good idea. That is what I would do.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
