Results 1 to 13 of 13
Thread: New FG pool balancing
    Oct 2014
    Rio Rancho, NM
    114
    The pool has been completely drained and filled 12 days ago.
    PB added some chemicals 9 days ago on Friday and told me he would be back, but hasn't yet.
    Yesterday I did my first test and here are the results:
    5/11/15 2:17 PM
    FC 1.0
    CC 0.5
    PH 7.5
    TA 120
    CH 75
    CYA 5 - estimate as I could still see the bubble and the tube was completely full.
    Salt 0
    Borate 0
    Temp 82
    So the question is, do I raise the CYA by using the autocholinator's tables or should I intervene?
    Also, for the chlorine, I'm thinking of just buying some bleach at Sam's club and drive the FC up.
    Whacha all think?
    Viking fiberglass Island Breeze II (16'x40'x8'); Pentair pump/filter/heater/chlorinator; IntelliTouch with iX+3; Autelis.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New FG pool balancing
    I would. Summer will be halfway over before you have adequate CYA if you wait for the pucks to do it all.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Bleach to raise FC is a great idea. I have a hard time reading what your CYA is the way you posted it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP! Congrats on the new pool!
    If you don't want algae to grow in your pool then you must keep the chlorine level above the minimum level for your CYA level based on this Chlorine CYA Chart. Even one day with FC below the minimum will give algae a foothold and it will start growing and you will have to SLAM your pool. Not adding CYA to your pool will require you to add chlorine more often during the day when the sun is on the pool because the sun will consume the chlorine faster without CYA in the pool.
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Does CYA = 120? Thats what im reading in the OPs list even though its staggered. If thats the case, you don't want ANY more CYA.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by umpalumpajay View Post
    That is how I read it too, so I a was confused on wanting to raise CYA.
    Lisa
    DFW, TX
    24,450
    DATE/TIME FC CC pH TA CH CYA Salt Borate Temp
    5/11/15 2:17 PM 1.0 0.5 7.5 120 75 5 82
    This is how I interpret it
    FC 1.0
    CC 0.5
    PH 7.5
    TA 120
    CH 75
    CYA 0
    Salt 0
    Borate 5
    Temp 82
    Oct 2014
    Rio Rancho, NM
    114
    Sorry guys for confusion.
    When I was posting it, the columns lined up, now they're not.
    Here are the results in column format -- I will also update original post:
    FC 1.0
    CC 0.5
    PH 7.5
    TA 120
    CH 75
    Salt 0
    Borate 0
    Temp 82
    Dec 2014
    West Hills, CA
    157
    oooooooh, hahaha! there was no "0" in the salt column and i have a tendency to read right to left (its a weird habit). Get some CYA and chlorine in that pool stat! LOL!
    Oct 2014
    Rio Rancho, NM
    114
    I've added 121Oz of 8.25% bleach from Sam's club this morning.
    If my calcs are correct, that should bring me up in line.
    What's the best option/source for CYA?
    I should say that I have a full bucket of the chlorine tablets that I don't plan on using much.
    I figured I will run the automated chlorinator if we ever leave town, but that's about it.
    If dumping 5-6 of those tables as a source of chlorine is a viable way and as a byproduct they will raise CYA to my target level (40), then I'm all for that.
    I will also point out that we do have automatic pool cover that's on all the time -- well, with exception of the 1 or so hour a day that the wife and kids swim.
    I say that because I hear that chlorine is burned of by direct sunlight and the amount of time the pool is covered almost totally eliminates that problem.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    You can buy CYA at Walmart or lowes. Usually about $14 for a 3lb container. Just put part of what you need in an old sock in the skimmer or in front of a return to dissolve. You can squeeze it every once in a while to make it dissolve faster.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Oct 2014
    Rio Rancho, NM
    114
    Quote Originally Posted by n240sxguy View Post
    Is this what I need:
    http://www.walmart.com/ip/HTH-Stabil...ioner/17043638
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That would be it.
    Jeff
