Thread: Staining
    Aug 2014
    East Northport, NY
    155
    Staining
    In our shallow end for about a 7 foot run on each side about 1 foot down in the water appears to be some staining. It isn't algae that can be brushed because I tried that. I am hesitant to put ascorbic acid in because I don't want to ruin the FC levels. I may take a magic eraser to it and see what happens. This stain was here last year as well for the duration of the season. You couldn't probably see it unless you look for it but now it's all I see.
    Any thoughts. I wish I could post a pic but it won't show it right.
    Thanks
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Staining
    I have read you can crush cheap vitamin C tablets and set or rub them on the stain.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Staining
    That's the trouble with having crystal clear water. You see every blemish on the pool surface, every stain, every blade of grass and flower petal that sinks in the pool.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Staining
    This is so true...lol
    Lisa
    Aug 2014
    East Northport, NY
    155
    Re: Staining
    Right the vitamin c is ascorbic acid. If I add that it will decrease the FC big time. I'm going to see if a mag ice eraser works first
    TF-100 Test Kit
    Aquabot Bravo
