Results 1 to 9 of 9
Thread: First time cleaning Pentair Cartridge filter - pressure relief
    Apr 2015
    Bay Area, California
    19
    Just opened and cleaned out the filter for the first time by myself!
    When restarting I forgot to use the pressure relief valve to blow out the air and get the steady stream of water coming out of the filter relief valve per the manual. The pipes rattled for 15 secs and then settled, filter sound okay but a little noisier than before cleaning and Psi reads at about 20 psi. I'm guessing the sudden rattle was air flowing through while the filter refilled. Is this normal? Should I open the relief valve while the filter is running ASAP? Or I'm okay?
    The flow rate feels really strong in the pool..pushed my hand strongly from the out take/return.
    Thanks folks,
    John
    38,271
    Re: First time cleaning Pentair Cartridge filter - pressure relief
    Welcome to TFP!!!
    Likely it was just the air making its way through the pipes. You should be fine, although you should still open the valve and make sure the air is all out. I pop mine open just about every week just to make sure there is no air building up.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes, I open mine while it is running to blow out air every time I clean the leaf basket.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    same here.. I open mine occasionally too.
    is 20 psi what your filter runs at? Or did you mention it because its higher than what you normally see?
    If its higher than normal, then it might just be stuck. It happens often. Just thump it with your finger and if it drops, it just got stuck.
    Divin Dave,
    Apr 2015
    19
    Wow. Fast replies!
    Okay, went and opened and gases out the filter this morning. Just a squirt of air and then water flow, so it looks like it's okay as y'all suspected! Filter sounds normal and the psi is running at 15 which looks to be about right...prior to the clean it was running at 30 psi.
    Good deal all!
    Hey one last thing do you folks keep a spare o-ring for the filter around for the just in case or does the o-ring last a good time before requiring changing? I put silicone grease/plumbers grease I got from ace hardware on it FYI.
    - 25,000 gallons in ground fiberglass pool
    - Pentair Clean and Clear Cartridge Filter
    - Pentair VS Inteliflo Pump, Pentair SolarTouch with Solar Panels - 8 hrs run time.
    - Poolmaster 22260 5-Way Test Kit
    - Polaris 380 with Hayward Booster Pump
    38,271
    I do not have a spare o-ring. In fact I think they might be discontinued for my filter.
    FYI, you should clean the filter when the pressure rises 20-25% over the clean pressure. With stating at 15psi, you should clean by 19psi.
    Apr 2015
    19
    Does a 20-25% increase translate into monthly cleanings?
    38,271
    Depends on how big your filter is and how dirty your pool is. If sized to our recommendations, you may only need to clean yearly.
    Please add your pool details to your signature as described HERE as it will help us help you.
    DFW, TX
    24,483
    Quote Originally Posted by John55 View Post
    Not likely. Most filters need to be cleaned a few times per year. Or at my house with lots of trees 2-3 times in spring and 2-3 times in fall.
