Thread: Easy touch and solar panels
    Apr 2015
    Las Vegas, Nevada
    25
    Hi,
    I am new to the pool world. Purchased house with inground pool and solar panels. I am thinking of purchasing easy touch system but wonder if it can operate the solar panels or I should keep the control box I got at the moment?
    Thanks
    12000 gallons inground pool with spa, Pentair VS pump, Easytouch 4, Intellichlor 40, Pentair Clean & Clear CC420 cartridge filter, solar panels, TF-100
    May 2011
    No. CA
    111
    Re: Easy touch and solar panels
    easy touch can operate solar valves.
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    Apr 2015
    Las Vegas, Nevada
    25
    I guess so it is true and for the temp sensors?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Yes, you can install temp sensors and a solar valve and the easy touch can control your solar same as a solar controller.
