Thread: Spa operating cost
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Spa operating cost
    I was trying to determine what it costs to operate my hot tub. It's 250 gallons / 120 volt and very well insulated. Currently it runs twice a day for 2 hours each cycle. I've been searching the internet for some average operating costs but couldn't find anything. Anybody have any suggestions?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Spa operating cost
    Quote Originally Posted by meatloaf
    Thanks
    It really depends on the usage. Your heater is what will draw the most electricity regularly (10 amps or so), so if you were to leave it covered all the time it would cost much less than if you used it nightly.
    Assuming it had to heat constantly for the 4 hours you ran it, you're looking at a maximum of 20 amps (2.4kW @ 120v). Now find your kWh rate. Let's say $.10. So you're looking at $.24 per hour, times 4 hours a day. Roughly $1 per day. So at most you're looking at $30/month. In reality, I'd be surprised if you used half that since your filter/heating cycle probably draws more like 12-17 amps and the heater won't be running that whole time. But again, depends on use, climate, etc.
    This is also assuming that the heater is only on during your filtration cycle.
