Results 1 to 9 of 9
Thread: Can't figure out how to balance PH and TA....
    Lrooth's Avatar
    May 2012
    Pittsburgh
    101
    I have a balance problem and am puzzled as to how to approach the fix. How do I get my ph higher without increasing TA? Or lower PH without raising TA? I have been slamming for week, going from black to almost clear... A bit cloudy now. Should I continue to slam or fix PH/TA? p.s. Waiting for a pump rePlacement... Working, but very loud. Not sure if this issue impacts solution.
    Readings
    FC: 3.75
    CC: .5
    PH: 6.9
    TA: 130
    CH: 80
    CyA: 20
    40,000 gallon plaster
    DE filter
    Lucy
    40K gal, painted plaster, Pentair FNS Plus 48, Hayward Super Pump 2 HP, Hayward H-Series-250, 50 years old, 3-month swimming season
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Can't figure out how to balance PH and TA....
    What test kit are you using?
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    If those numbers are correct, at least the pH and TA, aeration will fix your pH. If there's any waterfall or spa spillover, turn 'em on. If you can move the return eyeballs, point them up as high as you can so it creates ripples in the surface. There are a lot more ideas if you use the website search box for aerator or aeration.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    You can raise your PH by aerating the water by turning the your returns up so that it rolls the water good. It will do anything to your TA. Here is a link to how to do it.
    http://www.troublefreepool.com/conte...tal-alkalinity
    You need to keep doing your SLAM until your pool is clear. Here is a link to help you know when to stop your SLAM
    http://www.troublefreepool.com/conte...loss-test-oclt
    Let me know if you need anything else!
    Kim
    Lrooth's Avatar
    May 2012
    Pittsburgh
    101
    Thank you.... I'm using TFT TEST kit. Been using BBB for two seasons. It's working for me...and saving lots of money! My pool so big, it swallows up chemicals.
    I'll read up on the aeration. I don't have returns with eye balls. It's a 55 year old pool.
    No one seems to be panicking with my Ph so low. So now I won't! I'll take a chill pill and keep slamming. ...and aerate.
    Lucy
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Your TA isn't terribly high, mine gets up there sometimes. Use some 20 Team Mule Borax to raise your PH to 7.2 at least.
    Lrooth's Avatar
    May 2012
    Pittsburgh
    101
    It's been two weeks, black water has changed to sparkling, diamond flickering blue! I used bleach, soda ash, stabilizer and calcium hardness increaser. Oh yes, I used my TFT test kit.... No more pool stores!
    My ph is still 140, but PH has gone up to 7.4. As always, Thanks for your help!
    Lucy
    May 2014
    Franklin, NC
    9,187
    Great news!
    Support the site
    DFW, TX
    24,502
    Good job!
    If you want to gradually reduce your TA level here is how, Lowering Total Alkalinity. The only reason to lower it is if the ph is rising a lot and often.
