Results 1 to 13 of 13
Thread: Pollen
    May 2014
    Nashville tn
    13
    Pollen
    Hi everybody. I am a true believer as you guys set me up last year. I followed everything last year and just got to the point that I added about two cups of bleach a night and tested weekly and had awesome success. This year I am having a new problem. Of course I just opened the pool and yes it is still green, but I'm working on that. The issue I have is the pollen that is accumulating. It is sticking to the water faster than the filter can remove it. I woke up this morning and it look like it snowed in the pool. Is there a good method to battle this? image.jpg
    24 foot 52" above ground pool using BBB method, Cartridge filter, 1.5 hp pump, new to me in May 2014
    38,321
    Re: Pollen
    More pump run time to skim the surface, use a skimmer sock and clean it often.
    May 2014
    Nashville tn
    13
    Re: Pollen
    I have been running the filter around the clock. I tried the skimmer sock but it only lasted minutes since there is lots of stuff being filtered out right now. I could try it again now that I think most of the chunky stuff is out. I spent yesterday in the pool in my chest waders sweeping and pulling out leaves and nuts.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Pollen
    Skimmer socks for sure
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pollen
    Another vote for skimmer socks. Just keep an eye on them as they will capture a lot of junk and starve your pump of flow.
    Jeff
    May 2014
    Nashville tn
    13
    Re: Pollen
    Thanks skimmer socks are on and I'll check them in a little bit.
    Jul 2007
    Suwanee, GA
    528
    Re: Pollen
    My pool will look like that if the filer is not running. Once it's on, it clears up pretty quickly. I've used skimmer socks in the past, but I find them to be more trouble than they are worth. They will collect the finer stuff, but don't want to have to clean them every day. It's the filters job.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pollen
    Yeah, I can't use skimmer socks during high pollen season unless I stand there and swap them out every few minutes. I have had to clean my cartridges 3 times this spring and it probably needs another cleaning.
    Carlajo's Avatar
    Apr 2015
    Wellsburg wv
    8
    Re: Pollen
    Mine looked like that this morning, with a healthy dose of the neighbors maple tree helicopters thanks to a storm last night!! My filter ran all night, I can't keep up either.
    Intex 22X52 Ultra Frame
    Hayward VL Series Sand Filter
    Full Sun, No trees
    Taylor TF-100
    Gorgeous deck!
    Aug 2014
    Shallotte, NC
    693
    Re: Pollen
    I thought we were past that until TS Ana just decided to stay for a while.... I'm retired, so I can take care of it pretty effectively, sock after sock after sock, but just be patient... there is a lot of stuff in the pool, a lot more is falling and blowing, there's one you and about 9 gazillion pollen laden plants. It will pass...
    May 2014
    Nashville tn
    13
    Re: Pollen
    I guess it doesn't help living in the greenest state. I tried the sock last night and it clogged after less than 30 minutes. I wanted to let the pump run all night so I took the sock off. It looked a little better today but it seems I will never keep up. I cleaned my filter Saturday and I think it needs it again. This is going to be a long spring. At least I can now clearly see the second step and make out the others. The people at Walmart keep asking me if I have a crime scene I am trying to clean.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pollen
    Sorry the sock did not work. You should have told Walmart since you cannot see the bottom of your pool it may be crime scene...lol
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2014
    Nashville tn
    13
    Re: Pollen
    Well I did have two dead squirrels under the cover....don't know how that happened.
