Results 1 to 14 of 14
Thread: Newbie with numbers
    Jul 2014
    NJ
    46
    Newbie with numbers
    Hello everyone my first test, was not as difficult as I thought! (If I did it right lol ) I just opened tonight Here are my numbers:
    Ph-7.2
    Fc-1.5
    Cc-.25
    Ch 250
    Ta 100
    I THINK I need to add 43oz of bleach and 8.8 oz of washing soda. Is that correct? Do I need to SLAM the pool?
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Newbie with numbers
    Welcome.
    What test did you use?
    What does your water look like?
    What is your CYA?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,470
    That CC number does not make sense ... can you verify what you did for that number?
    There is really no reason to add washing soda. As long as the pH is in the 7s, you are fine.
    What is your CYA? That determines where the FC needs to be maintained.
    Jul 2014
    NJ
    46
    I am using the Tf100. Is the cya the tube test with the black dot? I saw the black dot the entire time. So I was confused.... The cc test I needed one drop. The water is clear.... Maybe I am doing entire thing wrong?
    Cartridge Filter.
    North New Jersey
    38,470
    Well 1 drop for the CC would be called 0.5ppm (assuming you used 10ml)
    Seeing the dot to the top means your CYA is less than 30ppm. Was any CYA added when the pool was built last fall?
    Jul 2014
    NJ
    46
    Ok so if my cc is .5 and my cya is less than 30 what do I do? I am not sure if any cya was added when the pool was closed. Someone closed it for me. They installed the pool and closed it the same day.
    Cartridge Filter.
    North New Jersey
    38,470
    Then I would guess your CYA is 0. I would use PoolMath to calculate how much stabilizer you should add to get to 30ppm. Then get that dissolving in a sock in the skimmer, squeezing as often as you can to help it dissolve.
    After adding the CYA, then assume you are at 30ppm and maintain the FC above the minimum listed in the FC/CYA Chart.
    It would not hurt to raise the FC up toward shock level and Perform the Overnight Chlorine Loss Test to see if there is anything in the water that would warrant the SLAM process.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Let me just add to what he said ^^
    You don't need to raise the pH. You're at the low end of good and your TA is high enough to push it up.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP! Congrats on the new pool.
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    Jul 2014
    NJ
    46
    Two more questions... In the pool math, where does my CC # go? If my CYA is 0 it says to add 79 oz of liquid stabilizer, do I do that all at once? Also can I add the bleach in at the same time?
    Cartridge Filter.
    North New Jersey
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    There is no place to enter CC in pool math. I would add 1/2 now add bleach 30 mins later. Check CYA in an hour. Then add more liquid Stablizer/ conditioner if you are not at your targeted CYA. Liquid gets in water faster so this is why you can check it sooner than granular Stablizer
    Lisa
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes CC is not something you adjust.
    I really encourage you to spend some time in Pool School. Start with the ABCs. Knowledge is the most important tool you'll have in your box.
    Essential Links:
    Casey's Avatar
    SW PA
    10,453
    Quote Originally Posted by Patrick_B View Post
    +1 You will gain most of your confidence in TFPC with knowledge. That old saying is true, knowledge is power.
    38,470
    The solid CYA granules are a lot cheaper than the liquid ... there is really no hurry to use the liquid.
    Also, I am not sure the liquid CYA would should up on the test in an hour ... that might be sporty. I would give it a day.
